Fuel pressure regulator
Ok guys I just wanted to know what fuel reg I should get, the one I've got at the moment is a standerd one. Don't know what bar I should be running either, I've got 83lbs Siemens injectors so need a good reg to suit.
Tell me if I need a 3 bar 3.5 bar or 4 bar????
Thanks
Thanks
It's easy. If you want to run 3 bar, buy a 3 bar. If you want to run 3.5 bar, buy a 3.5 bar....I hope you see a pattern emerging.
Or seeing as you are spending money and they are all adjustable anyway. You can just adjust it to whatever fuel pressure you want !
Although isnt the OEM one adjustable anyway ? The old 2wd certainly was.
Depends how much boost you are running, at 0 bar boost a std cossie regulator is set to run 3.5 bar fuel pressure, and rises at a rate of 1:1, so 1 bar boost will be 4.5 bar fuel pressure, 2 bar boost will be 5.5 bar etc.
SMILER258
Sep 28, 2015 09:04 AM
Dubs44
Sep 19, 2015 06:31 AM
