Engine warning light and MOT
Old Jan 7, 2012 | 08:24 AM
jt2k6's Avatar
jt2k6
Default Engine warning light and MOT
Due my MOT next week and I have a warning light on my dash. Not going to get a chance to get it fixed before it's due, Will I fail?
apparently it's a cam or crankshaft sensor, but seems to have no effect!! economy is as poor as ever, revs fine, flies along when requested, light just sits there shining at me!
btw its a R-Reg Vauxhal Vectra, would ask on Vauxhal forums but trust you lot more )
Old Jan 7, 2012 | 08:41 AM
Bloomers's Avatar
Bloomers
Cornish Fasty
it will now, depending on how strict your tester is. they have been given a couple weeks grace with the new guidelines, so you could be lucky
Old Jan 7, 2012 | 09:05 AM
Fordmad!'s Avatar
Fordmad!
Doubt its crankshaft as it would probably be playing up. Mates ex gf had an astra doing the same think that was camsensor
Old Jan 7, 2012 | 09:13 AM
Oranoco's Avatar
Oranoco
Usually it's Lamda sensor or MAF if economy is very poor.
Have to price up if it's worth bothering to repair with Vectras current values.
Old Jan 7, 2012 | 09:33 AM
focusv8's Avatar
focusv8
There's nothing in the new manual pulished on VOSA to say Engine management light on is a fail.
Some other warning lamps on are a fail.
Old Jan 7, 2012 | 12:36 PM
studabear's Avatar
studabear
pass and advise, regarding the eml
It may fail emissions though.
Old Jan 7, 2012 | 12:39 PM
Rollinz's Avatar
Rollinz
if economy is poor then its more likly to fail emissons
Old Jan 7, 2012 | 12:40 PM
7sean7m7's Avatar
7sean7m7
I thought if engine management light was on it was a straight fail now?
Old Jan 7, 2012 | 01:24 PM
Shings's Avatar
Shings
Same here...
There's been a number of posts about it recently.
Old Jan 7, 2012 | 01:33 PM
focusv8's Avatar
focusv8
From the Guardian newspaper;
There is a breathing space, however. Vosa, the government agency responsible for the MoT, has indicated that up to "late spring" – probably May, although the exact date hasn't been set yet – "failures" relating to the new tests will first be treated as "advisories". This means that if you are tested now and have a warning light that's faulty you will have until the next MOT renewal date to get it fixed.
Also no mention of engine management in the list from VOSA;
http://www.guardian.co.uk/money/2012...?newsfeed=true
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
dojj
15
Aug 18, 2015 08:21 PM
ar4ibaldo
Ford Focus ST
Aug 18, 2015 04:24 PM
Neatrags
Aug 16, 2015 07:57 PM
