Engine warning light and MOT
Due my MOT next week and I have a warning light on my dash. Not going to get a chance to get it fixed before it's due, Will I fail?
apparently it's a cam or crankshaft sensor, but seems to have no effect!! economy is as poor as ever, revs fine, flies along when requested, light just sits there shining at me!
btw its a R-Reg Vauxhal Vectra, would ask on Vauxhal forums but trust you lot more )
From the Guardian newspaper;
There is a breathing space, however. Vosa, the government agency responsible for the MoT, has indicated that up to "late spring" – probably May, although the exact date hasn't been set yet – "failures" relating to the new tests will first be treated as "advisories". This means that if you are tested now and have a warning light that's faulty you will have until the next MOT renewal date to get it fixed.
Also no mention of engine management in the list from VOSA;
http://www.guardian.co.uk/money/2012...?newsfeed=true
Stu @ M Developments
41
21-08-2015 06:47 AM
