Fiesta zetec s turbo engine mount
Thinking of doing a fiesta zetec s turbo (mk5)
But wouldn't use the zetec se engine.... What engine mount would you use if you wanted to fit zetec e?? Would an rs1800 one work?? Is the mount on the turret the same??
Cheers for your help
Black top mount is similar mointing position to se (i think). Silvertop is a rear mount.. Im back to working on this atm. Im thinking uprated gearbox mounts and a modified cvh mount
if you sign upto zsoc theres a 2.1 forged mk5 zs in imperial blue for sale now! silvertop engine its still being run in but worth a look! when you sign up this its the thread
http://www.zsoc.com/showthread.php?t=67939
for sale thread
http://www.zsoc.com/showthread.php?t=240132
pics
Some of the bits
1. Federal RSR Tyres
2. Avo fully adjustable coilovers
3. Rear Beam bushes, front anti rollbar uprated polyflex bushes
4. Full blue samco hose kit
5. Powerflex Exhaust Bushes
6. Powerflex Uprated front lower arm bushes
7. Vibra Technics Gearbox Mounts
8. Custom Rear Strut brace
9. Custom Flocked Dash
10. New front setup (new knuckles,bearings,hub assembly)
11. Ford OE Drop Links
12. Helix Clutch 210mm
13. Focus Rear disc conversion with mintex pads
14. New fuel tank
15. Hispec 4pot billet front brakes (285mm) with mintex pads
16. Uprated Master Cylinder and Servo
17. Fully stripped and painted engine bay
18. Omex 600 ECU
19. All new brake lines with Bias Adjuster
20. Mocal oil catch tank
21. 2056cc Zetec-E Engine
22. Supertech Forged Pistons
23. Eagle Forged Rods
24. Heavy Duty Main and Big end shells
25. ARP Rod bolts
26. Custom Baffled Sump
27. Bored, Honed, Decked Block (2.1)
28. Skimmed Head
29. Fully Balanced Bottom End
30. Refaced Flywheel
31. Hybrid T3 Turbo
32. Intercooler + pipework
for sale thread
pics
Some of the bits
14. New fuel tank
18. Omex 600 ECU
25. ARP Rod bolts
28. Skimmed Head
31. Hybrid T3 Turbo
Youngben,
Cheers but didnt wanna buy one!... Just have the urge to build a zetec turbo and always had a bit of a soft spot for the fiesta zetec s on escort cosworth wheels
That one does look clean tho
Jay, one above is 4000ono
rsfido_1989, Yeah had been thinking about boxes, some focus have rear starters. cheers for your help anyway
From my research it wont fit. You can fitna ka bellhousing onto a zs box to.fit it but a zs box wont fit... Ill find the link to where infound that out... If im wrong ill take the punishment like a man haha
Sorry slight reword... On a turbo aplication the starter 'may' be in the way but Na should be ok... I have all the boxes to try... Sorry for any bad advise iv been looking into it for a lil while on and off.
dnt worry mate, everyone gets things wrong time to time, i been thinking about this latley too as i really like the mk5 zs, just the engine mounting im confused with, surely it would be the zetec mk3 fitted to the mk5 shell? but also got to worry about what to do with the power steering, rad, intercooler as behind the bumper the mk5 is nothing like a mk3, tried looking at other build thread including one above but can seem to find much info on way things are fitted.
they are great little cars, this is my 2nd one now altho this is a project not a daily. yes its a zetec like the mk3 had fitted into the mk5. im looking for a mk3 fiesta to cut the inner wing mount off at my scrappy or i have also considered a modified cvh mount on a custom welded inner wing mount.
http://www.ebay.co.uk/itm/FORD-SIERR...6#ht_986wt_952
this is the kind of rad im looking at as i wont be using the lower rad hanger, ill weld mounts for this.
im not worried about power steering so manual rack or also some people keep but pack with grease the power rack for a quicker lock to lock.
http://www.ebay.co.uk/itm/UNIVERSAL-...#ht_500wt_1202
this is the style of intercooler im looking into so sit in the bumper under the number plate as there is a ideal space for it.
hope thats been more helpful than my other shite i started off with lol
Zs box won't fit. Bell housing is diff and starter will hit exhaust Mani.
Mk4 or 5 derv bell housing is what you need, puma box with this bell housing is best set up.
Mk3.5 Cvh inner wing mount is closest match to retro fit.
You can also use a mk6 escort long shaft to ditch the equal length shaft set up
Don't forget to upgrade the fuel pump. And need to go to mk4 fiesta dash clocks to get running on a frst loom ( if you want the rev counter and water temp to work
hell yes i knew someone told me it wouldnt fit but others on zsoc claim it does fit, dont feel as bad now lol, iv got the derv and endura box for building.. puma box when i kill them
As above. I'd be interested. Got a puma powered Zs and fancy chucking a 2.0 black top in. Been looking at the pin outs on a Zs and focus ecu and they look v similar. Might be able to use standard loom
JoeyBoyden
Jan 4, 2024 02:36 PM
vdun01
Ford Fiesta
Oct 5, 2017 08:14 AM
track.focus'd
Aug 12, 2015 05:53 PM
