what paint gives a gloss finish on an engine
Jan 4, 2012 | 04:00 PM
as above
Jan 4, 2012 | 04:09 PM
Gloss.
Enamel? Not sure on spelling.
Jan 4, 2012 | 04:13 PM
Quote:
Originally Posted by
CrOwSoN15
Gloss.
Yes both will mate.
CrOwSoN15
Gloss.
will that paint stand the heat of the engine
Jan 4, 2012 | 04:15 PM
Pretty sure enamel is what people use on the block/head etc. So yes it'll stand the heat
Jan 4, 2012 | 04:21 PM
cheers thanks for the help
Jan 4, 2012 | 04:23 PM
Jan 4, 2012 | 04:24 PM
Really? I didn't think 2k would be that good at withstanding heat.
Jan 4, 2012 | 05:39 PM
check the small print on the back of cans, they tell you the limits of heat they will withstand. im sure normal car spraypaint has quite a high temperature threshold once dried .
i did my cosworth rocker cover in normal spray paint, lasted 2 years no problem.
Jan 4, 2012 | 05:53 PM
Jan 4, 2012 | 06:12 PM
Coach enamel will be perfect for the job.
Jan 4, 2012 | 06:52 PM
enamel is the shit ,2k will rust in time
Jan 4, 2012 | 07:02 PM
Use engine enamel - Its for engines
2K wouldn't last very long IMO
Jan 4, 2012 | 07:46 PM
dingla rs
Paint doesnt rust
Jan 4, 2012 | 08:03 PM
head bloack and parts on my motor done in 2 k
fully cleaned , two coats of etch primer , coat of primer , 3 paint 2 clear iirc
just hoping the engines out the cupboard before it starts to rust afpmsl !!!
Jan 4, 2012 | 10:10 PM
All mine is done in 2k, block was cleaned fully then cure rust applied etched primed, primed then painted, seems ok so far, been painted about 4 years..
Jan 4, 2012 | 10:17 PM
Same as, i work in a bodyshop, used 2k for years when restoring cars and painting engines, never had a complaint about it falling off
Jan 4, 2012 | 10:21 PM
r thompson
hi
i did use on my engines
ALIPHATIC -URETHANE
olso you need a special primer to.
gloss finish take the heat work werry well check my block.
thanks ferenc
JoeyBoyden
Jan 4, 2024 02:36 PM
Wilsfoci
15
Mar 30, 2016 10:26 PM
muz
Aug 16, 2015 12:57 PM
