parrot handsfree how easy to fit?
Old Jan 3, 2012 | 09:42 AM
P4ULT's Avatar
P4ULT
Default parrot handsfree how easy to fit?
hi guys im thinking of getting a parrot ck3100 for my van nissan primastar 56 reg. been ringing round and getting prices around £180+sot lead if needed. but you can get them for abut £90 so just wondered if anyone has fiited there own or is it best left to the pros.
cheers guys
Old Jan 3, 2012 | 09:47 AM
Chip's Avatar
Chip
*** Sierra RS Custard ***
Absolute doddle if you have the right adaptor or if your vehicle is ISO anyway.
Check on an owners forum for that vehicle how to remove the radio, or look in a manual if you have one.
Once the radio is out it just plugs in.
Only thing that can make them a pain is if there isnt enough room behind the radio for them to physically go in terms of the main control box.
Old Jan 3, 2012 | 11:26 AM
Oranoco's Avatar
Oranoco
Fitted loads of the CK3100 kits and use one myself, superb bit of kit and very reliable.
As per Chip, total breeze to fit and if you have ISO connectors a 4 year old can do it. Budget 2 hours for a really neat install
Old Jan 3, 2012 | 11:38 AM
XRT_si's Avatar
XRT_si
If the Primastar is the one that looks like a Renault Traffic etc... and has a single DIN/normal sized stereo, then it's about as simple as it could be, there's a fair amount of room behind the stereo too. If it's the double DIN/big sized radio you will probably need the SOT lead, but still pretty simple.
Make sure you have your stereo code handy as wel if you need it.
Old Jan 3, 2012 | 11:42 AM
JamesR1's Avatar
JamesR1
Anybody for a brew?
A doddle. Fit them at work on a few cars. Worse bit is pulling dash apart on some cars when headunits are all inbuilt. if the radio pops out then as chip said can be tough if there isnt much room, very simple tho.
Old Jan 3, 2012 | 03:38 PM
ludacris s's Avatar
ludacris s
Does anyone know how hard would it be to fit to a Ford 6006cdc?
Old Jan 3, 2012 | 03:46 PM
cossiegreg1's Avatar
cossiegreg1
I was thinking about getting one for my ford connect. The van isn't plylined/ no bulkhead, so am i right, in thinking there is going to be much road noise coming from the back?
Old Jan 3, 2012 | 04:28 PM
XRT_si's Avatar
XRT_si
They can be a little tricky to remove, even with the right keys (you need 4 of them and it's easier with 2 people if you've not done it before). You will also need a SOT/adaptor lead for that.
To be honest, yes it is a bit of an issue, but depends what you can cope with. Moving the microphone closer to you can help.
Old Jan 3, 2012 | 04:33 PM
cossiegreg1
ok thought so, thanks
Old Jan 3, 2012 | 05:24 PM
UBster's Avatar
UBster
Fitted a 9200 and 9100, both in under 3 hours with 2 people.
Old Jan 3, 2012 | 05:47 PM
Shings's Avatar
Shings
If you're inexperienced at this type of thing leave it alone.
Stereo is a pain to get out if you're not competent and will need to have the correct keys - some of the poorer versions will require taking the locking mechanisms apart to remove the keys from the stereo and some of them wont release all pins so you may end up stuck with keys in the dash.
It will need a stereo lead to function properly but again if you're competent all connections are available on the back of the stereo including mute - if using a lead be careful to put the remote controls back into the new connector on the back of the stereo.
If it's going in a mondeo and you have the lead its a 25 min job including locating the microphone and an hour if you've never really done it before - Glove box comes out and side panel off the central console to give you easy access and loads of space.
Primastar
If I remember correctly - if the dash is like this http://www.zebravehicles.co.uk/phase-3-primastar.html you're better off going behind the instrument cluster as I don't think theres room behind the stereo.
It will all be torx screws and phillips anyways and as its a van will come apart quite nicely - I think the whole dash top comes off too.
Old Jan 3, 2012 | 06:32 PM
P4ULT's Avatar
P4ULT
Originally Posted by xrt_si
if the primastar is the one that looks like a renault traffic etc... And has a single din/normal sized stereo, then it's about as simple as it could be, there's a fair amount of room behind the stereo too. If it's the double din/big sized radio you will probably need the sot lead, but still pretty simple.
sure is the same as a traffic, single din stereo. Where is the best place to put the microphone as you seem to be in the know.
Cheers for all the replies guys.
Old Jan 3, 2012 | 06:45 PM
Shings's Avatar
Shings
As per my post... because you're going behind the binicle stick it on the drivers A pillar.
Old Jan 3, 2012 | 07:01 PM
P4ULT's Avatar
P4ULT
Thats the one mate dint see your post sorry so the a pillar is the way forward. cheers.
Old Jan 3, 2012 | 07:14 PM
Shings's Avatar
Shings
Yeh off the top of my head.... just remember it is a van so will be noisier than a car you could get away with on the dash - I've put them on the underside of the top panel before and had no complaints. Just have a play around - depending on what you can be ass'd to do.
In the primastar though it should be iso on the stereo.
Just need to make sure the + - and +/- are in the right places... all straight forward enough.
Old Jan 10, 2012 | 06:18 PM
P4ULT's Avatar
P4ULT
thanks for your help guys all done now as said it took a couple of hours and was not to stressful.
Old May 28, 2013 | 05:33 PM
marc_gti's Avatar
marc_gti
just to update this
im wanting to buy a ck3100 to fit into my works astra 2005 - ive bought an iso cable is this correct?
cheers
Old May 28, 2013 | 07:21 PM
Shings's Avatar
Shings
Originally Posted by marc_gti
just to update this
cheers
I'd need to see the back of the stereo as it might look like ISO but some of the GM/Vaux stuff was a 3 block ISO which complicated things.
Also being a GM/Vaux the standard stereo cage holds the blocks in place so you have to piss about with the removing the cage to get it all to fit properly. Good news is there's loads of room below the stereo to hide all the cabling - from memory. I think the ashtray comes out quite easily, 2 x torx screws.
All easy enough to do just need to take it apart and understand what's going on.
Old May 29, 2013 | 08:34 AM
XRT_si's Avatar
XRT_si
On an Astra you need to run an ignition live. Easiest place is from the heater control panel below it, which pops off. It will need a lead too.
Old Jun 4, 2013 | 09:52 AM
marc_gti's Avatar
marc_gti
that would be why i have a spare red wire then? is that all i need to so extra?
also been told that this car has a canbus style system does this make it awkward?
Kyle Langford
27
Aug 5, 2019 07:54 PM
Ethan sagoo
Aug 25, 2015 03:22 PM
Dr. Ickxs
Aug 15, 2015 11:34 AM
track.focus'd
Aug 12, 2015 05:53 PM
muz
Aug 1, 2015 06:48 AM
