Mk1 power figures
Old Dec 20, 2011 | 06:06 PM
OrionHayden's Avatar
OrionHayden
Ford mad
Default Mk1 power figures
What power figures are your mk1 frs' putting out and with what mods?
Old Dec 20, 2011 | 06:22 PM
JamboRS's Avatar
JamboRS
focus rs 1672
mines is over 300 and ive got exhaust,decat,pd manifold,dv007,forge actuator(blue spring) running 22psi and pro charge cooler rad
Old Dec 20, 2011 | 06:34 PM
Dicko&Vacant's Avatar
Dicko&Vacant
plenty in the 500s now mate
mine was about 450hp but its now in bits getting a rebuild
Old Dec 20, 2011 | 06:40 PM
bassboy's Avatar
bassboy
GT2860 turbo from SCC
Miltek manifold
Blueflame exhaust
Blitz boost controller
DS map
Radtec intercooler
Saw 306hp on the rollers running 18psi or 19psi boost...runs 22.2psi on the road in that spec...
The low power was due to the map...was running 9:1 as it came on boost!
The current spec is the same as above but a GT2871 turbo instead and its definitely more powerful as less boost! But it aint mapped to suit yet...
On order is:
Uprated fuel system - bigger injectors, external swirl pot, etc etc
Area 6 fully worked cylinder head
Area 6 valve train package
Area 6 cams - inlet and exhaust cams
Steel rods
Area 6 'zero-loss' inlet manifold
Then its off to MSD for a custom map
Then ill drive it and enjoy it for a while for about a year...then add a GT30 or equivilant (have a Turbonetics T61 sat here to ) and go for aftermarket management...then who knows!
Old Dec 20, 2011 | 06:49 PM
pee vee's Avatar
pee vee
K+N
dreamscience
007
decat
around 260 bhp.
Old Dec 20, 2011 | 06:57 PM
OrionHayden
Ford mad
mine has
Miltek de-cat pipe
Full scorpion s/s exhaust
Forge actuator
Bigger front mount cooler
K&N induction relocated
Bailey twin piston dump valve
Boost was told is at 13 psi but on the boost gauge it hits the end which is 1.5 bar
Not sure what power it is running but was told its estimated 250 minimum
Looking to get it re-mapped, what are the bluefins like upto a custom map?
Old Dec 20, 2011 | 07:00 PM
bassboy's Avatar
bassboy
Get an after market boost guage as I have heard the original ones arent very accurate...
A boost controller would be a good investment to...but expensive!
With your spec, I would imagine anywhere between 250-270hp with a remap would be attainable!
Bluefins are fine with your spec...if you want to go down the route of a hybrid turbo or a GT28 etc, then I would get the GT28 spec BF, or go for a custom map from MSD
Old Dec 20, 2011 | 07:03 PM
OrionHayden
Ford mad
Will look into getting a aftermarket boost gauge. Will maybe just go for bluefin then as im sure i will have enough power with what i have as a daily
Old Dec 22, 2011 | 05:13 PM
simonRSfocus's Avatar
simonRSfocus
If the car is running those mods with standard map it will not be making good power, especially with a decat!a bluefin will liven it up and it will run sooo much better with the mods!all tho I have seen a few people disappointed with the new bluefin map as it just dumps large amounts of fuel in to cover the AF cough!so dreamscience may be a better rout or a demon pete stage 2 map!I woulsd get yourself onto the rs owners club and have a search you will find a hole load of useful information on bluefins etc
Old Jan 4, 2012 | 08:03 PM
olliehampton's Avatar
olliehampton
17psi. De cat. Full pipe kn panel and 007 275bhp. Was told its one of the best he'd seen with the mods.
Old Jan 4, 2012 | 08:08 PM
Rollinz's Avatar
Rollinz
Miltek manifold
Blueflame exhaust
DS map
Radtec intercooler
On order is:
Steel rods
dont bother..... get your self some 1.8 N/A cams from ebay
545.4 bhp offically on paper. at 1.4 bar
at 1.7 bar i experienced "valve float" but still make 586 bhp.... more to come
Old Jan 13, 2012 | 05:31 PM
R5 5KOT's Avatar
R5 5KOT
Miltek turbo back
Bluefin
260 ish
wowk
Mar 30, 2021 07:49 PM
Daniel Howard
Ford Classics & Vintage
Oct 3, 2015 10:44 PM
Sep 28, 2015 10:05 AM
Tank Mike
Sep 26, 2015 08:07 AM
