Metal Water pipe issue with GT30
Old Dec 4, 2011 | 03:01 PM
BRAMMER's Avatar
BRAMMER
Default Metal Water pipe issue with GT30
Has anyone else had issues with the metal water pipe that runs down the ex side of the head fouled by the compressor housing on large turbo's?
Whats the solution?
Old Dec 4, 2011 | 04:44 PM
Gav Diamond's Avatar
Gav Diamond
Is a common issue bud, cant remember how I sorted mine though.
Might be worth speaking to one of the tuners as sure they have fitted loads of these size turbo's
Old Dec 5, 2011 | 02:30 PM
R4N SS's Avatar
R4N SS
never thought of that being an issue - bollocks
Old Dec 5, 2011 | 06:41 PM
Ridgey's Avatar
Ridgey
Sounds like a bit of pipe bending is in order.
Old Dec 5, 2011 | 07:36 PM
NEIL A's Avatar
NEIL A
If it is still bolted to the boss on the side of the head the you need to unbolt it and trim back the boss to gain clearance, I'm sure that's wha that'd to be done on my old car that was running a 2wd manifold.
Old Dec 5, 2011 | 08:48 PM
chrisa3's Avatar
chrisa3
Boss?? Mines been running loose between heater connection and pump. Im sure thats what my vibration is. Where is it supposed to be fixed to?? (im only running a T34). Anyone got a photo ??
Old Dec 6, 2011 | 12:33 AM
BRAMMER's Avatar
BRAMMER
Thought about that, what it ideally needs is cutting in the straight section and then rewelding in another position which.is looking like the only option but I'm worried about vibrations
Old Jan 7, 2012 | 03:20 PM
BRAMMER's Avatar
BRAMMER
This is how i got around the problem - just fitted a new silicon 90° hose and hay presto
Old Jan 7, 2012 | 04:57 PM
v man's Avatar
v man
Zee Germans are coming
could you not cut the water pipe that goes to the water pump then loosen the metal pipe off at the bulk head end this then twisting the bend of the water pipe toward the water pump then this should pull the metal pipe closer into the head
if that makes sence
Old Jan 7, 2012 | 05:58 PM
Ridgey's Avatar
Ridgey
Presume that won't be in the way of the small water hose to turbo or cooler?
Old Jan 7, 2012 | 08:17 PM
BRAMMER's Avatar
BRAMMER
if that makes sence
The pipe is the only way it will go with the turbo fitted as the compressor housing is so big and close to the head as i'm not using a spacer block in the manifold due to space - the only other option for the bend is the cut and reweld at 90° anti clockwise
Clears all, just but looks neat too
155lee
Sep 6, 2016 11:10 AM
Rsmat
63
Sep 25, 2015 12:11 PM
gcfcos
88
Sep 15, 2015 03:48 PM
jonfoc
Sep 11, 2015 04:46 PM
hopper350
Sep 4, 2015 12:53 AM
