Main & Big End Bearings/Shells. Who' are best?
Old Nov 29, 2011 | 08:02 AM
DixieTheKid's Avatar
DixieTheKid
Pick-up P100 Power!
Default Main & Big End Bearings/Shells. Who' are best?
Hi all,
Im rebuilding my cossie lump, need to get some new main & big end bearings. I see there are a lot to choose from but which are the best quility/valve for money. Burtons are expensive, Graham Goode seem reasonable.
Thanks
Old Nov 29, 2011 | 08:13 AM
BigErn's Avatar
BigErn
I use Glacier Vandervell when doing my engines, usually get them from Graham Goode
Old Nov 29, 2011 | 08:34 AM
DAN400's Avatar
DAN400
i ve mahel bearings in my new engine, i got mine from matt lewis.
but i also ran pinto bearings for over 5 years,never had an issue,and that was with over 400bhp too,
only reason for my rebuild was my block cracked
Old Nov 29, 2011 | 10:54 AM
dug112y's Avatar
dug112y
passionford pro
just make sure you measure them all to make sure clearance is good...all of the ones metioned are good....plastigage and the right micrometer are your friend. if your not sure find someone who is IMO.
Old Nov 29, 2011 | 10:58 AM
LHD220Turbo's Avatar
LHD220Turbo
Mahle's are fine; matt lewis is your best bet
Old Nov 29, 2011 | 01:11 PM
DixieTheKid
Pick-up P100 Power!
Ł227 from Matt Lewis there Mahle
Old Nov 29, 2011 | 02:08 PM
AJC's Avatar
AJC
I have used ACL in the past with no issues
Old Nov 29, 2011 | 02:23 PM
RS SHAUN's Avatar
RS SHAUN
ACL's in mine
Old Nov 29, 2011 | 02:47 PM
DixieTheKid
Pick-up P100 Power!
Just rung Graham Goodes, they say there's are Mahle. Ł50 a set so that will do me.
Old Nov 29, 2011 | 03:14 PM
DAN400's Avatar
DAN400
not a chance are they the same bearings that matt lewis is selling at Ł227
Old Nov 29, 2011 | 03:38 PM
DixieTheKid
Pick-up P100 Power!
Got him to put it in writing via email.
Old Nov 29, 2011 | 03:41 PM
Hoogi's Avatar
Hoogi
When they say a set.............are you sure they have that right ????
Are they talking Big & Little End Rod bearings or as mentioned + Crank bearings ?
If Big & Little then the VAT...........that would be Mahle at around the same price at Matt Lewis.
To be fair to Matt - GGR would work out more expensive
Old Nov 29, 2011 | 03:43 PM
DixieTheKid
Pick-up P100 Power!
Set of 10/8 MainsLinky BigendLinky
Old Nov 29, 2011 | 03:48 PM
Hoogi's Avatar
Hoogi
Just Crank then............if they are Mahle - I'd say get them
I think Matt Lewis is costing for the full Bottom End - which is a good price.
Old Nov 29, 2011 | 05:39 PM
opposite lock's Avatar
opposite lock
ACL,s in mine too
Old Nov 29, 2011 | 06:20 PM
chrisa3's Avatar
chrisa3
+1 - Think I got mine from Woodford though.
Old Dec 2, 2011 | 07:53 AM
leo_cos's Avatar
leo_cos
Has any one else had problems with acl race bearings? Do they require a high pressure oil pump or is standerd fine?
Old Dec 2, 2011 | 08:34 AM
LHD220Turbo
no need for HP oil pump IMO
Old Dec 2, 2011 | 10:22 AM
leo_cos's Avatar
leo_cos
Okay cheers
37
Sep 17, 2015 05:05 PM
Maxwell
Fiesta ST
Sep 13, 2015 05:31 PM
rsstav
Sep 7, 2015 04:43 AM
