Best place to buy a new 2WD HP Oil Pump ????
Old Nov 24, 2011 | 07:57 PM
Hoogi's Avatar
Hoogi
Default Best place to buy a new 2WD HP Oil Pump ????
I rang Burton Power today........they said they won't have any in for 3 weeks.
Trouble is I want to have the engine back together ASAP as I'll be working away again for a while.........time isn't on my side.
I've also looked on ebay - there are some for sale but unsure of the quality ?
Any advise ????
Old Nov 24, 2011 | 08:08 PM
Sonic Boom's Avatar
Sonic Boom
GGR do them for Ł89.99 here's the eBay link;
http://www.ebay.co.uk/itm/GGR471-Upr...item255d2693aa
Rich
Old Nov 24, 2011 | 08:40 PM
Cragrat's Avatar
Cragrat
sit boo boo sit
Nice one sonic...
Old Nov 25, 2011 | 07:10 AM
Hoogi's Avatar
Hoogi
Thanks very much........
Old Nov 25, 2011 | 08:24 AM
COLEYST200's Avatar
COLEYST200
just get this pump and put your lid on it . 1/2 the price and it will do the job . at the end of the day a cosworth YB is only a pinto . and i have to ask why do you need a HP pump ??
http://www.ebay.co.uk/itm/FORD-PINTO...item43a887c8c3
Old Nov 25, 2011 | 08:27 AM
Chip's Avatar
Chip
*** Sierra RS Custard ***
As per above, why do you want a high pressure pump?
It will increase the chances of your turbo seals being overcome by oil pressure.
Old Nov 25, 2011 | 09:58 AM
DAN400's Avatar
DAN400
when i was looking for a pump matt lewis told me to get one off protech motorsport,
they re on ebay , they have made the pumps for cosworth in the past,
its been 100% so far
Old Nov 25, 2011 | 01:04 PM
Hoogi's Avatar
Hoogi
Coley / Chip,
Great stuff..........very much appreciate the response.
I thought a HP Unit would flow more oil compared to a standard pump. And therefore keep more oil on more of the components, more of the time.
I've just spent a lot of money on an Arrows Crank, Rod and Cosworth Pistons and while I have the sump still off I thought it would be a good idea to also replace the Oil Pump.
I've an RS500 Engine in my MKII Escort but just running 4 injectors and a T34.63 as I think more than say 350bhp will be too much for the car and my driving skills. A very reliable 350bhp would be just what I'm looking for.
I just want to get it right..........fit and forget
So, a standard Oil Pump would do the business ????
Old Nov 25, 2011 | 01:15 PM
COLEYST200's Avatar
COLEYST200
yes mate a standard oil pump will do the job very well . the big thing why motors go sick is the oil that is put in them . iv got a pinto pump in my 3dr here are some photos of my old oil pump that was killed when the crank went and a pinto pump next to it
Old Nov 25, 2011 | 01:16 PM
Chip's Avatar
Chip
A higher pressure pump doesnt actually have the ability to flow anymore oil, all it will do is at times when the standard pump was bleeding flow off because pressure is sufficient, it will push that through the engine instead of back into the sump to increase pressure further.
Ie at the times (like at idle) when the pump doesnt flow enough to maintain pressure it will make no difference, the only time it will flow more oil is at the times that you have enough flow anyway.
Ultimately different people will have different opinions, but personally I think that the standard pressure is plenty and that more doesnt benefit you but makes it more likely that seals will fail etc.
Might be worth posting a "is a high pressure oil pump a good idea" thread and see if you can get a few more people's opinions though.
Old Nov 25, 2011 | 01:54 PM
Hoogi's Avatar
Hoogi
That is great Gents.........I'll purchase a standard one.........again thanks for the info.
big_Rad
Sep 15, 2017 09:36 AM
Dubs44
Aug 21, 2015 02:42 PM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
MARKYMARKONE
Aug 20, 2015 12:55 PM
adam151082
Aug 11, 2015 04:50 PM
