my cheap way of weighing my car
Old Nov 23, 2011 | 05:29 PM
scoooby slayer's Avatar
scoooby slayer
Default my cheap way of weighing my car
lol it worked though
terrible picture but its just 2 bathroom scales with a piece of wood on top.
Old Nov 23, 2011 | 05:37 PM
Ridgey's Avatar
Ridgey
So how heavy was the car?
Old Nov 23, 2011 | 05:49 PM
scoooby slayer
lighter than i expected, and much more balanced than i expected, between all four corners weighed at same height it ranged from 190 - 215 kgs. around 800 kg total but almost 50/50 weight distribution
Old Nov 23, 2011 | 06:09 PM
Ridgey's Avatar
Ridgey
Nice and light
Old Nov 23, 2011 | 06:20 PM
scoooby slayer
Nice and light
i quite chuffed considering its got a stonking iron v8 in it
Old Nov 23, 2011 | 07:28 PM
stu21t's Avatar
stu21t
thats how i corner weighted the 5 lol
this might be helpful
http://robrobinette.com/corner_weight_calc.htm
Old Nov 24, 2011 | 07:09 AM
scoooby slayer
i was worried i didnt have enough weight over the drivewheels, but with the front of the engine situated about 6" behind the front axle and the heavy rear axle its worked out almost 50/50 split plus im fitting a rear spoiler hopefully it will be stable at 100mph+
Old Nov 24, 2011 | 07:38 AM
stu21t's Avatar
stu21t
When you did it, did you have all the wheels at the same level as the 1 you were weighing?
Ie scales and 4x2 under all the wheels or 2 lots of 4x2 under the other 3 wheels, if not the measurement wont be accurate.
And did that include your weight? Cos that will add more to the rear.
Old Nov 24, 2011 | 07:41 AM
scoooby slayer
yes mate i blocked all wheels at same height 5" off the ground, without blocks made about 10 kg difference.
that was half tank fuel but no driver, im 90kg aswell so she'l be almost 250kg each rear drive corner.
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
c14rks
Aug 11, 2015 05:17 PM
vdubo7
Aug 2, 2015 08:17 PM
BMROVAL
Shows & Track Days
Jul 31, 2015 05:32 PM
