Ford Range This section is for other models in the Ford range.
Transit connect 4 stud conversion
Old Nov 20, 2011 | 12:27 PM
connect_4's Avatar
connect_4
Default Transit connect 4 stud conversion
I want a bigger choice of wheels for my connect, ideally i want some Compomotive MO's.
the choice of wheels for the 5 stud pattern is small so i want to convert to 4 stud.
What parts do i need ?
Will the hubs from a Focus Zetec fit the front, what about the drums on the rear - which car will i need them from ?
Don't want to go for a rear dics conversion, no need for that.
So what do i need to change from a 5 stud to 4 stud keeping the drums on the rear.
cheers
Andy.
Old Nov 20, 2011 | 12:32 PM
Cragrat's Avatar
Cragrat
sit boo boo sit
Would it not be easier to convert if to 5x112 loads of wheel options available
Old Nov 20, 2011 | 12:33 PM
Cragrat's Avatar
Cragrat
sit boo boo sit
Would it not be easier to convert it to 5x112 loads of wheel options available
Old Nov 20, 2011 | 12:34 PM
connect_4's Avatar
connect_4
i don't know, whats involved in this ?
5x112 what wheel options are there ?
5 x 114 is more popular - jap car fitment ?
Cragrat's Avatar
Cragrat
sit boo boo sit
Damn double posting phone.....
Old Nov 20, 2011 | 12:37 PM
Escow-Van's Avatar
Escow-Van
Volvo use 5x108 if you're interested. Saw a connect on some old T5 alloys a while ago, suited it really well.
Old Nov 20, 2011 | 12:45 PM
connect_4's Avatar
connect_4
Don't really want volvo wheels, i like the compomotives and such like.
So can anyone help me here ?
To convert my Connect to Ford 4 stud what do i need ?
1) 2 front hubs - WHICH CAR DO I GET THEM FROM
(can i keep my Connect original driveshafts ?)
2) 2 rear hubs / drums - WHICH CAR AND WILL I NEED WHOLE BRAKE ASSEMBLY ?
3) 2 front discs
CAN ANYONE SHED SOME LIGHT ON EXACTLY WHAT I NEED TO GET ?
cheers
Andy
Old Nov 21, 2011 | 02:07 PM
connect_4's Avatar
connect_4
anyone ?
Old Nov 28, 2011 | 09:39 AM
fas's Avatar
fas
Hi mate you'll need to go to a scrap yard with someone breaking a st170
Take the front hubs with calipers etc
Get the rear hub and calipers, the rears are straight bolt on and plus it's a disc brake setup on the back, so will look better
In regards with the front you may have an issue with fitting your drive shaft not sure, you'll need to find out if there's a difference in splines in the cv joints
Hope this helps
Old Nov 28, 2011 | 10:33 AM
gouch1's Avatar
gouch1
would standard focus ones fit
Old Jan 8, 2012 | 01:37 PM
atm's Avatar
atm
rs front hubs fit (the actual hub part, remove the bearing and just change the hub, keeping your connect knuckle) and your shafts should be fine with them..
but regarding the rear im not sure, limited really unless you go for a disc setup at the back
but surely theres plenty of wheel choice since whatever fits on a focus mk2 also fits a connect...
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Cosnada
Jan 7, 2016 05:30 PM
Mark RS
Oct 12, 2015 06:01 AM
Neil Clark
21
Oct 1, 2015 07:02 PM
stevecfrst1
Sep 30, 2015 05:18 AM
