Anybody Good With Audi's?
Old Nov 18, 2011 | 09:21 AM
MikeyRobbo's Avatar
MikeyRobbo
PS3 - MikeyRobbo
Default Anybody Good With Audi's?
Bought an Audi A4 as spares or repair off ebay, cambelt snapped at lights apparently. Heads been off and the following work has been done;
Head Skimmed
Valves Checked And Reseated
New Head Gasket
New Cambelt
New Tensioner
The car will not start, there is very very low compression in all 4 cylinders, won't start off a bump start or nothing, fuel is getting up and there is a spark and timing is correct according to Autodata.
Its a 2.0 Petrol ATL
Old Nov 18, 2011 | 10:09 AM
SiZT's Avatar
SiZT
Has the head been pressure tested?
Old Nov 18, 2011 | 10:27 AM
MikeyRobbo's Avatar
MikeyRobbo
PS3 - MikeyRobbo
Yeah, done a leak test on the pistons too
Old Nov 18, 2011 | 11:42 AM
DanW@FastFord's Avatar
DanW@FastFord
Spelling Club King!
Have you done the work on the car, or have you been told that's what's been done?
Old Nov 18, 2011 | 12:36 PM
MikeyRobbo's Avatar
MikeyRobbo
PS3 - MikeyRobbo
All of the work was done here in the garage, apart from the head works, but that was sent off to someone who we've used for years and never had a problem with, they even sent someone out to see if he could solve the problem, he suggested the leak test which proved nothing.
Old Nov 18, 2011 | 12:39 PM
Chip's Avatar
Chip
*** Sierra RS Custard ***
Have the lifters had time to pump back up?
Try taking the plugs out and spinning it over for a while, see if the compression improves then.
Old Nov 18, 2011 | 12:40 PM
Sp3no's Avatar
Sp3no
Is it a non interference engine? If not then i would have expected at least one bent valve, sounds like you have at least one in every cylinder. Have they timed it 180 degrees out?
Old Nov 18, 2011 | 12:41 PM
Joshy's Avatar
Joshy
Dreamer
have you fitted the correct head gasket? silly i know but possible.....
Old Nov 18, 2011 | 12:42 PM
Chip's Avatar
Chip
He said the valves were checked and seated though?
Mind you, might not have been done properly, lol
Old Nov 18, 2011 | 12:44 PM
Sp3no's Avatar
Sp3no
Thats what i was thinking
Didnt realise you were back chip, welcome back, right where you belong
Old Nov 18, 2011 | 12:55 PM
MikeyRobbo's Avatar
MikeyRobbo
PS3 - MikeyRobbo
All the valves were taken out, inspected then lapped in so none are bent
Old Nov 18, 2011 | 01:02 PM
foci's Avatar
foci
i would have said lifters. plugs out and good old turn over.then compression test
Old Nov 18, 2011 | 01:33 PM
andi-p's Avatar
andi-p
Check the Cam pulley is on the correct way round. IIRC they can be put on either way round and have 2 very different timing marks on each side. Hope this helps.
Old Nov 18, 2011 | 07:05 PM
St3V3_C's Avatar
St3V3_C
Surely this would mean the valves are closed longer than they should be, so pumping them up won't increase compression? Decrease it if anything...
Old Nov 18, 2011 | 07:08 PM
Cossie Sean's Avatar
Cossie Sean
big floppy donkey dick
lifters cause the valves to stay open
Old Nov 18, 2011 | 07:14 PM
martysmartie's Avatar
martysmartie
I would say you have bent valves, despite being ok when fitted, was it definitly times up correctly, else this could have bent them since?
As said lifters open the valves, so if they were suspect you would have the complete opposite effect, i.e. high compression, in any case I can't see it would stop the valves opening.
Martin
Old Nov 18, 2011 | 07:34 PM
Cossie Sean
take the cam/followers out (whatever is easyest) then compression test, easy.
Old Nov 18, 2011 | 07:36 PM
GVK.'s Avatar
GVK.
That will bend the valves.
edit - no it won't!
Old Nov 18, 2011 | 07:38 PM
St3V3_C's Avatar
St3V3_C
If they have no oil in them, they will be short, and the valve will stay closed. Surely?
Old Nov 18, 2011 | 07:39 PM
andi-p's Avatar
andi-p
if the lifters are taken out the valves will be closed.
Old Nov 18, 2011 | 07:41 PM
andi-p's Avatar
andi-p
I may be inclined to check the oil pressure at the cylinder head. I have heard the head gasket can go the wrong way round and stop oil getting to the head.
Old Nov 18, 2011 | 07:42 PM
Cossie Sean
they get pumped, locked, extended too far when removed if they dont get all the oil squeezed out before refitting, very bad practice to fit without doing this IMO because this happens!
"That will bend the valves."
how? seriousley..... how?
cams and or lifters out, belt off, ALL valves are 100% closed under spring pressure and if seated properly will have compression, if not head back off.
St3V3_C's Avatar
St3V3_C
What? Taking the followers out? Don't be silly *
* unless this engine is built very different to everything else...
Old Nov 18, 2011 | 07:45 PM
andi-p's Avatar
andi-p
if the valves can not opened there will be no air to compress to get a compression reading. If the readings are low to start with I would look at top end oil pressure to see if the lifters are getting the oil they need.
Old Nov 18, 2011 | 07:47 PM
Chip's Avatar
Chip
Cant compression test it with the cams out, it wont be able to breathe any air in.
You can only leakdown test it like that.
Old Nov 18, 2011 | 07:50 PM
Cossie Sean
see your point
im aproaching this differently due to it having a lot of work and possible hidden faults from last owner/destroyer
interesting one.
Old Nov 18, 2011 | 08:06 PM
Chaz888's Avatar
Chaz888
the only thing that I can think of relates to lifter ,when I done the v8 I got a new lifter set and even though this was a new build engine and I drill primed the oil system it was a long lead time before it would run.
Old Nov 18, 2011 | 08:15 PM
kaisersolsay's Avatar
kaisersolsay
I had the exact same issue when rebuilding my brothers 1.8T A4. I timed the head sprocket and crank perfectly and turned her over by hand to get the oil into the cam followers, however I wasnt aware that there are actually timing marks stamped on the rear of each cam which need to also line up. As a result I bent all 8 exhaust valves. My guess you've done the same. See link below to a thread that will show you the rear cam timing marks. Its very easy to miss as most cars time on just the front cam and crank.
http://www.passatworld.com/forums/61...tensioner.html
See below link also to a video of my brothers car turning over.....at the time I couldnt work it out so removed the head and discovered all 8 exhaust valves were bent....gutted as I had just replaced them all!
If your engine sounds the same on turn over the exhaust valves are bent mate sorry.
http://s182.photobucket.com/albums/x...10205-1132.mp4
Old Nov 18, 2011 | 08:34 PM
focusv8's Avatar
focusv8
Would this be them?
Old Nov 18, 2011 | 08:37 PM
kaisersolsay
Hey yes thats my bro's valves......and the wifes kithen table cloth!
Old Nov 18, 2011 | 08:43 PM
GVK.'s Avatar
GVK.
Oh yeah, I'm a daft cunt.
But as Chip says if valves are closed then the engine cannot inhale/exhale thus no compression.
Leak down test will prove if bent valves or blow by on the pistons of course.
Old Nov 18, 2011 | 08:47 PM
MikeyRobbo's Avatar
MikeyRobbo
PS3 - MikeyRobbo
ill try all the things suggested when i can quite busy in the garage tomorrow i think, pretty sure we got the back little arrow timing marks on the cams though as we used Autodata to confirm the timing first. I'll ask the boss though as it was him who done it first time round.
Quite worried about that video though, sounds the same, but there is a slight popping noise as if its firing, but its not a big enough bang to kick it into life, which is what low compression would explain. Really hope the valves haven't had a fight with the pistons though, its a 20 valver
Edit to add;
To do a leak down test i remove the belt and cams, what about spark plugs, what shall i replace them with?
Old Nov 18, 2011 | 08:59 PM
stevieturbo's Avatar
stevieturbo
C**t
How about the leakdown test tool ?
Old Nov 18, 2011 | 09:01 PM
MikeyRobbo's Avatar
MikeyRobbo
PS3 - MikeyRobbo
Rightio!
Old Nov 18, 2011 | 09:24 PM
focusv8's Avatar
focusv8
Spooky, Eh?
Good link for the cam chain change.
Might be usefull in the future, as I've just bought a high mileage 1.8T Skoda, runs O.K now I've replaced the blocked oil pickup tube (common problem).
markk
Sep 9, 2015 08:11 AM
oilman
Trader Parts for Sale.
Sep 4, 2015 09:34 AM
turbowag
Sep 3, 2015 08:07 AM
