Ford Focus (All Models) This forum is for discussion of all things pertaining to the Ford Focus Range that doesnt belong in the seperate ST & RS sections..
keyu central locking working intermittently
Old Nov 17, 2011 | 09:06 PM
lewby's Avatar
lewby
Default keyu central locking working intermittently
Hi,
Hope someone can help. Now it is getting a little colder my central locking has started not working. I dont have a fob, only key central locking.
The problem is that i can only unlock each door individually, then whenever it feels while driving the whole car unlocks and you can then lock and unlock a few times from the drivers door before it stops working again. A few locks and unlocks usually get it working for a short time. However using the passenger door only unlock that door both with the key and internal switch.
I think maybe the solenoid has gone on this door, but not sure and dont want to spend to check if i can help it. Anyone got any ideas? I have tried replacing fuse 63, even though it was not blown.
Thanks
Old Nov 27, 2011 | 11:13 PM
Cozziekid's Avatar
Cozziekid
Try having a good ol' squirt around the door catch mechanisms with WD40 or plusgas. Common fault to have these start to seize up especially in the bad weather.
Old Dec 6, 2011 | 09:46 PM
lewby's Avatar
lewby
tried that but it didnt really do anything
Ben26
Ford Focus Diesel
Aug 18, 2015 03:42 PM
Seanyfarrell
Aug 14, 2015 11:37 PM
yawiejon
15
Aug 9, 2015 06:36 PM
Red_bull
Aug 9, 2015 08:34 AM
