st170 ignition warning light
Old Nov 16, 2011 | 08:04 PM
eva de silva's Avatar
eva de silva
Default st170 ignition warning light
i got light come on dash pic of battery i believe its ignition warning light so my book says. anyone had this problam? also i read other posts about error codes coming up where do they show up in car? and whats the so called dash trick?
Old Nov 16, 2011 | 08:11 PM
RichieST's Avatar
RichieST
That's a warning that the alternator isn't charging the battery. Check with a meter what voltage you are getting across the battery. Forget the dash trick, it's useless and irrelevant, it only displays dash fault codes, not actual engine dtc's.
Old Nov 16, 2011 | 08:27 PM
eva de silva
ok thanks where do dtc things show up on dash? i keep hearing bout them. and are you saying i need fix alternator to new one
155lee
Sep 6, 2016 11:10 AM
Dr. Ickxs
Sep 15, 2015 10:15 PM
morg65
Escort MK 5 / MK 6
Sep 11, 2015 01:55 PM
fuzzy
Sep 4, 2015 10:11 PM
hopper350
Sep 4, 2015 12:53 AM
