Ford Focus Range This Section Contains All The Ford Focus Model Specific Forums.
Mk1 Focus Black gearbox problem
Old Nov 15, 2011 | 08:16 PM
paddy675's Avatar
paddy675
Default Mk1 Focus Black gearbox problem
The gear lever normally self centres between 3rd and 4th gear position. When you push across to either 5th / reverse it springs back to centre position, but if you push across to 1st / 2nd it doesn't spring back to centre. Does anyone have any ideas? Is there a spring that pulls it back? If so where is it located? Please can someone help
Cheers Paddy
Old Nov 15, 2011 | 09:19 PM
hogdog's Avatar
hogdog
Assuming it's a 1.4, 1.6 or 1.8 then it's the return spring at the base of the gearstick, it will have snapped. It's a common problem and a new spring is about Ł5 from Ford's. It's a fiddly job but it's a fairly straight forward D.I.Y job. You'll need to remove the centre consul to get at it.
Old Nov 16, 2011 | 08:22 PM
paddy675's Avatar
paddy675
Default focus gearbox problem
Hi Hogdog thanks for your reply, the car is a 1.6 engine. Do you know what Ford list the part as, is it just a gearbox return spring? Removing the console top and gearknob exposes the linkage mech do i need to remove the whole console to get to the spring?
Thanks for your help. Cheers Paddy
Old Nov 16, 2011 | 08:37 PM
hogdog's Avatar
hogdog
No problem, the part no. is 1142069.
Yeah, you'll need to remove the whole consul, it's not really difficult, the hardest bit is getting it over the handbrake, you'll need to pull that up as high as you can.
If you then move the gearstick around you should be able to see the spring at the base. I think you need to remove some screws to get to it.
For future reference it usually gets broken when you go from reversing to pulling away in first without having fully come to a stop.
Old Nov 17, 2011 | 08:22 PM
paddy675's Avatar
paddy675
Many thanks, will get the part and give it go on Saturday.
Cheers Paddy
CLIVE
Oct 2, 2015 12:58 PM
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
nick8saff
Aug 16, 2015 05:35 PM
saph in dorset
Aug 14, 2015 10:10 AM
track.focus'd
Aug 12, 2015 05:53 PM
