take a look at this
Have you got a photo with the bottom pulley removed?
Would it be possible to modify a 2wd bottom pulley of a Cosworth?
If not i'm sure you could have an alloy one custom made.
Also an another idea does the power steering pump pulley line up with either of the two V's on the excisting bottom pulley might just be a case of putting a longer belt round the Bottom Pulley, Water Pump and then the PAS pulley.
Rich
Rich
In fact thinking about it it would probably be easier to make a bracket to line the PAS pulley up with the outside V of the bottom pulley and run a belt round them. If they don't already line up that is.
Rich
Rich
thanks for the help
see thats a crankshaft pulley and a cosworth crankshaft is different
as far as my options go i honestly think the best option would be to take the original pulley off and get another v built onto the front of this
would this be a good idea? and do you think it would be expensive?
thanks for the help
Your best bet is to get the pas pulley to line up with the bottom pulley and run a longer belt.
Rich
i havent actually had the pulley off but i screwed the bolt out and its alot smaller than the one that came with the cosworth pulley
who would i ask that would know if the cossy pulley will go on here?
Bolt size shouldn't matter, it may just be that the Cosworth crank takes a bigger bolt. You really need to take your original pulley off and try the Cosworth one on.
Can you not get pintos that had power steering from the factory? May eb easier to use bits of one of those?
