SEC Monitor switches, Where from ?
I have an early model SEC monitor that i need to replace the 2 push switches on are these still availeable ? or is there an alternative i can use .
This any good?
https://passionford.com/forum/trader...addresses.html
Edit: Thought you meant alternative as in a different monitor, sorry.
something like this will do, if you look around you will probably be able to get ones the same as the original
http://www.ebay.co.uk/itm/1-Mini-Pus...item3f0af3c014
rsguy
44
29-09-2015 03:29 PM
