1.8 Zetec Ka Problems
Old Nov 10, 2011 | 12:51 PM
Gazz_'s Avatar
Gazz_
Default 1.8 Zetec Ka Problems
Any ideas why it would be cutting out when you rev it ?
The engine is from a 1.8 Focus.
Runs fine otherwise.
Old Nov 11, 2011 | 07:05 PM
Churtz's Avatar
Churtz
Cuts out when you come off the throttle and the revs drop back down?? Or cuts out as you press the throttle??
Matt
Old Nov 11, 2011 | 07:15 PM
Gazz_'s Avatar
Gazz_
Cuts out as you press the throttle.
Old Nov 11, 2011 | 07:44 PM
Adam.'s Avatar
Adam.
Needs Beer Tokens.....
MAP sensor.
Old Nov 11, 2011 | 07:47 PM
Churtz's Avatar
Churtz
Umm, unless your on custom management you won't have a MAP sensor. Does it happen if you accelerate gently? Sounds like you under fueling on initial accel.. More than likely tps.
Matt
Old Jun 10, 2012 | 12:40 AM
bigbro's Avatar
bigbro
hi i have recently converted my 1.6 cvh engine mk4 orion to a 1.8 fiesta zetec engine using the fiesta ecu and loom wired into my own loom car starts fine but as soon as the engine warms up and you try to drive it it starts splutering and losses power to the point where it hardly moves when you press the accelerator to the point where it tries to cut out help me please
morg65
Escort MK 5 / MK 6
17
Sep 11, 2015 08:40 PM
grishenko45
Sep 9, 2015 12:58 PM
BRAM
Sep 8, 2015 07:11 AM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
little bram
Sep 7, 2015 11:59 AM
