Bleeding brakes help
Old Nov 5, 2011 | 07:49 PM
jay's Avatar
jay
Default Bleeding brakes help
Hi I'm lookin for some help to bleed the brakes on my escort. I have fitted all new pipes servo and abs block it will let me bleed the fronts but not the rear even if I try turning on the ignition. It seems as if the pump is not working but have tried 2 different ones to be sure it wasn't that?? I'm really stuck if anyone can help would be much appreciated!!
Old Nov 5, 2011 | 08:00 PM
botters's Avatar
botters
competant bodger
iirc you need some weight on the rear to allow fluid through you cant do it with the wheels off the floor
Old Nov 5, 2011 | 08:48 PM
jay's Avatar
jay
Would the servo still not work if the wheels are off the floor?
Old Nov 6, 2011 | 07:36 AM
jay's Avatar
jay
Anyone????
Old Nov 6, 2011 | 09:12 AM
dojj's Avatar
dojj
Resident Wrestling Legend
what escort is it?
Old Nov 6, 2011 | 11:32 AM
martysmartie's Avatar
martysmartie
Originally Posted by dojj
what escort is it?
LOL I would guess a Cosworth given the threads location.
By you saying you can't hear the pump makes me think you have a electrical problem, power etc? (Assuming the second pump was known to be good)
The servo assistance is achived by means of an electronic pump which you should hear run when the ignition is in position one, they don't have a conventional servo!
It makes no difference whether the car is on the ground or not.
Martin
Old Nov 6, 2011 | 05:12 PM
jay's Avatar
jay
Martin
spot on mate! the pump im using is good and have tried another just to be sure! i agree with you about the wiring but were do i start?? i even checked to see if there is power goin to the abs ecu. is it known for the ecu's to go down?? is there anyone local to bedfordshire whos willing to have a look?
cheers
Old Nov 6, 2011 | 05:15 PM
martysmartie
The pump is independant from the ECU, there is a pressure switch built into the system, this is what switches the pump on, (It's fitted to the Master cylinder) so it could be this, most problems are usually caused by a faulty relay, blown fuse etc.
Martin
Old Nov 6, 2011 | 05:21 PM
jay's Avatar
jay
checked and changed the fuses and relays might try changing the pressure switch again to be sure.
do you no what triggers the pressure switch? or how to check it works?
Old Nov 6, 2011 | 05:23 PM
dojj's Avatar
dojj
the abs loom is stand alone other than the wires going to the ignition and fuse box, it doesn't intergrate anywhere else into the loom
main problems are the power relays under the dash, there may be 2 or 3 of them, yellow and purple
start with those as the pump needs to buzz upon start up to give you the pressue required
Old Nov 6, 2011 | 05:27 PM
jay's Avatar
jay
its in the back passenger quarter on mine? i have checked the fuses and relays next to the abs ecu? is there anyway to power up the switch to make sure it works??
Old Nov 6, 2011 | 05:28 PM
martysmartie
Yes pressure as the name implies
You could always try bridgeing the wires as a test, there is a special Ford tool needed to remove it, although you may be able to improvise something.
I can't remember the figures off hand but the system works under very high pressure, hence the warning triangle on the Accumulator, so make sure you are comptent in what you are doing before dismantling the system!
Martin
Old Nov 6, 2011 | 05:32 PM
jay's Avatar
jay
Martin
there is 5 pins on that switch think i would need a wiring diagram before i break something lol
Old Nov 6, 2011 | 05:35 PM
martysmartie
LOL true, you can either PM "Jon@work" on here, or do a search on here as there are plenty of diagrams etc.
Martin
Old Nov 6, 2011 | 05:52 PM
jay's Avatar
jay
spot on mate thank you will let you no how i get on
Old Nov 7, 2011 | 08:45 PM
jay's Avatar
jay
sorted!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
thanks for the help boys spot on!
Old Nov 7, 2011 | 08:48 PM
dojj's Avatar
dojj
what was it in the end?
Old Nov 7, 2011 | 09:02 PM
jay's Avatar
jay
The motor in the pump was seized
Old Nov 7, 2011 | 09:45 PM
waynev1979's Avatar
waynev1979
i knew it was that.....i wont say i told you so
Old Nov 8, 2011 | 05:41 PM
martysmartie
No problem, glad it's sorted.
Martin
Old Nov 8, 2011 | 09:27 PM
jay's Avatar
jay
You wish lol
Old Nov 8, 2011 | 09:28 PM
jay's Avatar
jay
Martin
Nice one mate
muzzman1
Sep 30, 2015 08:59 PM
Sp3no
Sep 27, 2015 07:23 PM
