JIC fitting to Fuel Rail - Cosworth
Im in the process of putting parts together to fully aeroquip my fuel system on my Saff Cosworth. Ive bought a second standard Fuel rail and Im about to order some AN06 weld on fittings to convert the standard rail.
My question is what material adapters do I need?? Im going to take them to Pirtek and get them to silver solder the fittings onto the rail, but the adapters are available in Stainless steel, mild steel and Aluminium.
I have read that aluminium doesnt silver solder, so was thinking steel would be better as the standard fuel rail will be steel also??
Anybody on here got an idea of which will be better for fitting to the standard rail??
Also, if I do go steel, im assuming the aluminium AN fittings will still bolt upto the steel fittings ok??
thanks in advance.
thanks in advance.
Hi Pal,
I have done loads, cut the ends off the standard rail, that leaves square section hole, use a steel 9/16 JIC male/male machined down to slide inside the square hole, silver solder the gap, polish it up, job done...
Ian
Ian
http://www.ebay.co.uk/itm/6-AN6-Male...item2566c9a29d
I was advised to use only mild steel when silver soldering which mine was done- i'm not overly confident in the way mine was done - they spun mine down straight and slotted over the original end then silver soldered around the base - they assured me it is fine but i'm not convinced so would like to have it brazed
http://www.ebay.co.uk/itm/6-AN6-06-M...item2a15805e0a
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
Aug 14, 2015 07:29 AM
Zoggon
Aug 10, 2015 10:39 AM
