ST170 Help
Hi i'm new here. I have owned my 52 plate ST170 for 8 months and for most of that time it has had an annoying stutter. This happens mainly between 30-40mph in 3rd or 4th gear. The car dosent run as smooth as id like but when you go through the revs its fine and revs freely.
The stutter isnt like a miss fire. Its more like the engine holds back on and off for a couple of seconds. There are no fault codes but its been plugged into a snap-on diagnostic machine which shows the e-vac isnt working propely but i have already changed this and checked the vacume and other pipes coming from that and all seems fine.
Hope someone can help as my patience is really running out of patience
and would like to sort it before i sell it in the next couple of weeks.
Adam
and would like to sort it before i sell it in the next couple of weeks.Adam
There is a flutter at low rpm between 2000-2200, it almost feels like your driving into a strong wind and the car is holding back but at soon as you get through it the engine should rev freely. If your having issues throughout the rev range i would start to look at either the coil pack or fuel pump starting to fail
Im glad its normal. I am putting the car up for sale so its a relief to know its nothing major. How muh would you guys suggest putting it up for.... Its 52 plate, blue, 29000 miles, good condition, only minor stone chips, FSH????
Adam
Adam
Just having a dig around the site and came across this post, looks/feels like my recent 04 plate purchase had the 2000ish rpm stutter. How come Ford never came up with a fix for this problem if all ST170s have this problem ?
I owned a 170, very dissappointed with the car, a fuel filter change helped a little but it drank the stuff when you tried to eek out what little performance you had. Gearbox is a joke too. I prefered the raft of standard Mk1s ive owned over the years. The RS is definately the Mk1 to go for.
You need to "live data read" your Lambda probe
Had exactly same problem
Tried plugs, coil pack, leads etc - still "stuttered"
Replaced Lambda and now perfect and big improvement in fuel consumption
Anyone know where the best place to buy them from? Direct from ford I presume?
My Snap-On Solus ultra was able to "live read" the engine sensors etc
What I found was the Lambda gave a flatline constant reading regardless of revs, load, emmissions etc etc BUT because it was inbetween the minimum and maximum permitted parameters the ECU did not register a fault and therfore did not store a code or put a warning lamp on.
After replacing the lambda the "live reading" gave a "peak and trough" reading that altered with the engine load, speed, throttle position etc
As said before all is now perfect and better fuel consumption
Have found this on http://www.sparkplugs.co.uk/pages/pr...Sensor-ccp.asp
Front Sensor
Part Number
Stock Code
Price (Ł) Each
Buy
OZA488-D2
1757
49.5+vat
Stock Code
Price (Ł) Each
Buy
OZA488-D2
1757
49.5+vat
Rear Sensor
Part Number
Stock Code
Price (Ł) Each
Buy
OZA381-D3
0462
49.5+vat
Stock Code
Price (Ł) Each
Buy
OZA381-D3
0462
49.5+vat
Haven't got the ability to live feed. Is there any software available to use with a laptop? Currently only have a basic obd reader.
But i see what your saying.
They aren't badly priced but isn't the preferred replacement bosch?
Andypandy260
Sep 23, 2015 10:28 PM
