yeah you can do that if you like,or take the amal valve off,does the same thing,will increase your boost spike. as long as you dont go potty they are fine.
an amal valve is just an electric bleed valve mate!3 take offs,one goes to atmosphere thatll be the metering head one.mine has one fitted in line from the actuator,leaving the amal valve there at the mo!
comp housing goes one end of bleed valve
actuator hose the other
then wind it out to increase boost!
