Any Audi tt techies about?
Old Oct 31, 2011 | 02:57 PM
terry mardi's Avatar
terry mardi
Default Any Audi tt techies about?
A few months ago the rev counter, fuel gauge and water temp gauge stopped working on my 2000 tt & at the same time the low oil pressure warning light started to flash.
I've had the clocks changed now & the fuel & temp gauge are working fine but the rev counter still doesnt work and the low oil pressure lights still flashing.
The pressure is ok as ive had it checked but someone said the warning light could be flashing as it takes a reading from the rev counter as well as somewhere else.
Any ideas what could be causing it folks?
Old Oct 31, 2011 | 03:07 PM
flannigan's Avatar
flannigan
sounds like you have replaced the faulty dash with another faulty dash mate they are a common problem on the audi tt check out http://www.bba-reman.com/catalogue/D...edProduct=2086
Old Oct 31, 2011 | 03:11 PM
terry mardi
It was a brand new dash supplied & fitted by Audi main dealers mate.
Old Oct 31, 2011 | 03:17 PM
flannigan's Avatar
flannigan
in that case you have a communication problem between the ecm and the instrument panel ecu have you had the error memory read from both units ?
Old Oct 31, 2011 | 03:29 PM
terry mardi
Do you do that with a vag com mate? I had a friend put on a vag com but he couldn't clear the some of the faults as it wouldnt let him or something (i cant remember the exact thing he said but can find out).
Old Oct 31, 2011 | 03:35 PM
flannigan's Avatar
flannigan
yes mate the faults that would not clear are present and may be related to the issues you are describing ie can comm between engine ecm and instrument ecm
Old Oct 31, 2011 | 03:37 PM
Fil's Avatar
Fil
ELASTIC BAND
Any reason you've not gone back to them? They must have charged a fair amount! ( unless a warrenty job? )
Old Oct 31, 2011 | 04:23 PM
terry mardi
So is it best for me to give it in to an audi specialist to check out? I was hoping to sell the car cheap soon but not give it away because of some annoying problem
Theres a re-call on the clocks from years ago, mine had never been changed so they honoured it.
Old Oct 31, 2011 | 04:36 PM
Fil's Avatar
Fil
ELASTIC BAND
Fair enough. You asked on any audi forums? www.audi-sport.net
flannigan's Avatar
flannigan
you need a diagnostic check done at least to see whats going on mate
Old Oct 31, 2011 | 07:07 PM
terry mardi
I'm not on that forum but I'll register.
I need to find someone close by with a vag com.
Old Oct 31, 2011 | 08:30 PM
Fil's Avatar
Fil
ELASTIC BAND
Where abouts are you?
I do have a Gen usb lead somewhere? Tho no laptop
JoeyBoyden
Jan 4, 2024 02:36 PM
Oranoco
41
Feb 11, 2016 01:28 PM
Oranoco
12
Oct 2, 2015 02:18 PM
Eigdoog
48
Sep 19, 2015 11:03 AM
M K
Aug 12, 2015 06:57 PM
