Chip will not allow full boost
Old Oct 23, 2011 | 03:03 PM
mtommi's Avatar
mtommi
Default Chip will not allow full boost
I have a chip on an L8 ecu only a stage 1 but it has never allowed me to boost past 8psi it has done it from new. Standard chip allows more boost. Anybody got any ideas????
Old Oct 23, 2011 | 03:21 PM
martysmartie's Avatar
martysmartie
Standard software allows around 10PSI, if it sees anymore than 13PSI a hard cut will be activated.
Whos the author of the chip, what actuator do you have and does your Amal valve work?
Martin
Old Oct 23, 2011 | 03:32 PM
mtommi's Avatar
mtommi
Martin
MSD stage 1 with closed loop -31 actuator, amal 100% working. Is there something else that is needed?
Old Oct 23, 2011 | 03:36 PM
BigChuck's Avatar
BigChuck
have you contacted MSD and asked them?
Old Oct 23, 2011 | 03:53 PM
mtommi's Avatar
mtommi
TBH I just sent a couple of mails to STU but got no reply(he is probably flat out). Trying to talk over the phone is a nightmare as I cannot understand them nor them I. Might give it a go if I have no luck on here.
Old Oct 23, 2011 | 03:58 PM
martysmartie
Assuming it's not a fuelling issue etc, then the best person to talk to would be the chip author, i.e. MSD.
No stage 1 is standard hardware, essentially it just allows a higher boost pressure to be run and remapped ignition curves.
A -31 actuator is reccomended, which you have anyway!
Martin
Old Oct 23, 2011 | 04:13 PM
mtommi's Avatar
mtommi
Martin
CheeRS fella appreciate the help.
Old Oct 23, 2011 | 04:16 PM
martysmartie
No problem mate, let us know how you get on and the outcome!
Martin
Old Oct 23, 2011 | 04:25 PM
James @ M Developments.'s Avatar
Feel free to send the chip back and I will check it for you. There should be no boost cut on a stage 1 as they go out of range of the map sensor
Old Oct 23, 2011 | 04:48 PM
Paul_RS's Avatar
Paul_RS
Knackered actuator or leaking dumpvalve? I had a faulty standard dumpvalve on mine, only allowed the car to boost to around 14 psi, took it out and it jumped to something like 25psi without touching anything else.
Old Oct 23, 2011 | 05:36 PM
martysmartie
Very true! To the OP what do you define by it won't go any further, does it physically hold back etc?
Martin
Old Oct 23, 2011 | 06:55 PM
mtommi's Avatar
mtommi
Itjust revs on and holds the same lower pressure. I tried it in today again to see if it would work again but alas no good. The second time i took it out i broke two of the pins stoopid cont i am but i soldered two back on but as these were on the closed loop part im curious as to know is the chip still useful. James i will need the lower closed loop part again as even though i soldered them back on it is mickey mouse tbh. Thank you very much james for the offer of looking at it. I will send it on to you on the chip and if you let me know how much i owe you for it i will send it with the chip.
Old Oct 23, 2011 | 07:03 PM
mtommi's Avatar
mtommi
Standard dump valve on mine paul and actuator is new also same time as chip. So that should be ok. In saying that i got a new sytec fuel pump a few years back and after a long time of the car cutting out discovered the pump was a bad un. Got really fed up with the fecker and didnt really care about it in fact i hated it and am only now getting interested in it.
Old Oct 23, 2011 | 07:05 PM
stevieturbo's Avatar
stevieturbo
C**t
Sure you have the right map sensor for the chip ?
Has it ever went properly ?
Old Oct 23, 2011 | 09:37 PM
mtommi's Avatar
mtommi
Well it goes mint on the standard map sensor and chip it is a 2bar one and goes to full boost on it. I will wait to see the diagnosis from MSD now as I could scratch my head all night wondering what it is. Its a bleedin pity I live so far away from MSD as they know what they about.
Old Oct 24, 2011 | 08:11 AM
The lower part is the encryption key,
just fire it in with an invoice and a note explaining what it is, and i will look at it for you. dont worry about payment yet mate.
Old Oct 24, 2011 | 11:12 AM
mtommi's Avatar
mtommi
CheeRS James will do.
Old Dec 26, 2011 | 01:32 PM
mtommi's Avatar
mtommi
Well huge thanks to James @ MSD who sorted me out. Car is spot on now. I must say MSD are really really good on customer service. Again big thanks James
Old Dec 26, 2011 | 02:33 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
So what was wrong ?
What you boosting to now ?
Steve
Old Dec 26, 2011 | 02:46 PM
Rsmat's Avatar
Rsmat
Quality service at MSD... Well done James.
Old Dec 26, 2011 | 06:01 PM
mtommi's Avatar
mtommi
[QUOTE=cossie4i_;5745091]So what was wrong ?
Steves
I really dont know I just left it in the capable hand of James.
Boosting to the proper 1bar now feels just nice to drive on the road.
Old Dec 26, 2011 | 09:34 PM
CHUNKYS RS's Avatar
CHUNKYS RS
i have a stage 1 chip on mine and am very happy with it just a quick question tho you said with a stage 1 it will boost out of range is this a good thing should i fit a 3 bar map as well as mine boosts to 17psi but as i understand it sensor will only read to 14.5psi
Old Dec 26, 2011 | 09:59 PM
no you can't use the 3 bar item on the stage 1 as the scaling is different,
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
Nov 3, 2015 04:08 PM
Marino
Sep 12, 2015 11:10 AM
markk
Sep 9, 2015 08:11 AM
