1.8 zetec turbo issues
Old Oct 20, 2011 | 03:59 PM
Camel Fiddler's Avatar
Camel Fiddler
Resident Camel Stalker
Default 1.8 zetec turbo issues
Hi all
I'm having a few problems with my car. It just had the turbo redone recently (few 000 miles) and doesn't appear to be that.
Basically the car idles poorly (~750rpm) and if the car is reved to about 2000rpm then dropped to idle, the revs drop down below 750 then back up. If I try to move the car just on the clutch, it'll try to stall. All of which I believe is iscv (asked this before). Correct?
Also, at this moment as my car uses a standalone ecu set up and had no dv or recirc fitted as new, I'm seeing how the car runs with an atmospheric dv. It smells rich (has a decat
Old Oct 22, 2011 | 09:26 AM
CarParts Express's Avatar
CarParts Express
Check all vac pipes on back of inlet manifold
Old Oct 22, 2011 | 09:55 AM
Camel Fiddler
Did that first. Forgot to mention. Did the carb cleaner sprayed down the back test then used like a stethoscope of vac hose to listen for anything. Nothing both times. Reset Ecu which improved it a bit
Old Oct 24, 2011 | 08:55 PM
Camel Fiddler
Bump if anyone knows??
Old Oct 24, 2011 | 08:58 PM
v man's Avatar
v man
Zee Germans are coming
take it for a set up mate
can you not adjust the idle at the tb
Old Oct 24, 2011 | 09:01 PM
COCHYN's Avatar
COCHYN
Man with all the issues you've brought up about your car, you really need to take it to a reputable tuner to work out all the bugs. Cheaper and much less heartache in the long run.
But as for the issues you mentioned, I hope you've put proper plugs in it this time. Otherwise, check your ISCV and MAF sensors, as well as any hairline splits in vaccum hoses. Not that many of them, so check them all.
Old Oct 24, 2011 | 09:08 PM
nevsrevs's Avatar
nevsrevs
as above book it in, and try and ajust idle, check your speed sensor too
Old Oct 24, 2011 | 09:44 PM
Camel Fiddler
Idle is fine. I adjusted it off tb to 900rpm and is much happier. Is it normal for revs to rise slightly when pressing brake pedal firmly on a stationary idle? Sure I had put that question in which is what I really wanted to know.... Strange. Just wondering if it could be a brake vac leak.
It lost 500ml of coolant but no hg symptoms and hasn't dropped anymore that I've noticed. Is it possible for coolant to get into where the plugs are? Just as it splutters for a few seconds initially then not again til next morning and there is water or some fluid visible in exhaust tail pipe.
Old Oct 25, 2011 | 12:55 AM
t230's Avatar
t230
Default t230 /t190
Mate, if u search on here you'll see my various rants and posts about either a problem with my focus or me having a go at a certain tuner etc etc..
My advice is, and this advice im giving you i beg you to take because i didnt and am still offroad after 3 years of heartache...and only now have given in to letting a tuner sort it for me but i may still have to go down the road which is the way i want to show you:
A) either have the pectel ecu unlocked and remapped at an approximate cost of Ł295 + vat for ecu clear reset ( i have been quoted this by cosworth/pi research) and have the pectel remapped by a REPUTABLE TUNER! Which is at an hourly rate plus VAT and it takes a good part of a day..
b) THIS IS THE ADVICE TOTD GAVE ME BUT I DIDNT TAKE "...we had a t230 in before and it gave us so much trouble. In the end it was the ecu! Once we replaced it there were no problems...." Those words will haunt me forever...so please mate START WITH THE ECU...
Please correct me on any info i have given people and also please excuse my grammar.
Just an additional note to anyone who may take notice....does anyone have a set of CHAMPION REC501C sparkplugs lying around for sale? these are the best plugs to use...NGK rs ones just crack..as for densos - theres so much misleading information out there..
Old Oct 25, 2011 | 09:00 AM
luke19790_3's Avatar
luke19790_3
Can't you use the denso for a focus rs?
Old Jul 2, 2012 | 06:10 PM
t230's Avatar
t230
Default sorted
Yeah, ive ended up using itv 22's........basically it turned out to be a faulty map sensor, fuel pump was on its way out and the wires i used to repair the coil to ecu connector were of a too high resistence so re-soldered with a new connector and et viola got all power back, wheels spinning etc after 6 long years of pissing about in my spare time lol HOWVER on my third go of putting my foot down with full boost THE CLUTCH WENT..HEY HEY NO SURPRISED AT ALL..................but all good ...................
Old Jul 2, 2012 | 07:09 PM
Camel Fiddler
Least you're getting there mate get an RS clutch in there
robnock
21
May 13, 2019 05:29 PM
Dubs44
Aug 21, 2015 02:42 PM
coozer
Ford Focus Range
Aug 15, 2015 10:26 PM
gingerturbo
Aug 11, 2015 09:44 PM
Cameron
14
Aug 9, 2015 06:28 AM
