fuel pressure regulator
Old Oct 16, 2011 | 02:15 PM
franssusilo's Avatar
franssusilo
Default fuel pressure regulator
hi guys...need some opinion here..
i got an escort cosworth that has been fitted with 803 green injector, -31 actuator, and fuel pump. I'm gonna up the boost to approx 1,3bar (19psi).
Do you think I need to change the standard 3,5 Bar fuel pressure regulator into a 4 BAR? Or just use the standard 3,5Bar?
Thank's guys...
Old Oct 16, 2011 | 02:48 PM
Sonic Boom's Avatar
Sonic Boom
No mate a standard FPR is well upto the job.
As long as it's set to 3 Bar with the Vacuum pipe on and 3.5 bar with the vacuum pipe off it will be ok.
A standard frp will have a raising rate of 1:1 so for every 1psi of boost you run the frp will raise the fuel by 1psi.
Which is exactly what you want.
Rich
Old Oct 17, 2011 | 12:09 AM
franssusilo
Rich
I forgot to mention that i already replace the standard ECU into HALTECH.
And planning to dyno tune it and set the boost at 1,3 Bar ( 19psi ).
So the standard FPR will do the job then?
And is the standard FPR is a 3 BAR or 3,5 BAR ? I thought it's 3,5 BAR?
Thanks again...
Old Oct 17, 2011 | 10:42 AM
James @ M Developments.'s Avatar
Std reg is 3.5 bar with no depression on the reference pipe.
The std one is fine for well over 500bhp, the only issue you have eventually with them is that they dont flow enough fuel if you run 2 pumps etc for big power fuel supply, then you end up with too much pressure in the line as the reg cannot bypass enough.
Old Oct 17, 2011 | 03:03 PM
franssusilo
Thank You for all the informations guys...
Really helpfull and appreciate it!
timsrs
Nov 13, 2018 11:48 AM
SMILER258
Sep 28, 2015 09:04 AM
Dubs44
Sep 19, 2015 06:31 AM
