Ford Classics & Vintage Discuss all other Ford cars here, from the classics to Vintage to the Australian and American Fords!
What engine for my MK 2
Old Oct 4, 2011 | 10:48 PM
jashami's Avatar
jashami
Default What engine for my MK 2
Hello. Im looking to get 200-250 BHP for my MK 2 Escort, currently on a 2 litre Pinto and wondering what options I have? I dont have a clue...all I know is that I wanna stay normally aspirated non-turbo.
Can I endlessly tune at the Pinto, or is there a bigger lump that can be dropped in to avoid a whole lot of hassle and expense?
Ive heard of things like Vauxhall red tops, etc.
What non turbo route do I have for 200 BHP plus?
Thanks for any advice lads.
Old Oct 4, 2011 | 10:53 PM
J1mbo's Avatar
J1mbo
B1mbo
Yb atmo, head work, cams, STD bottom end with a set of 12:1 pistons, throttle bodies, pectel t2 and mapped on the dyno, just done one tonight, pair of proper cams gave 240 at 7500 and 8000rpm
Old Oct 5, 2011 | 10:38 AM
jashami's Avatar
jashami
Forgive my lack of knowledge but whats the"yb atmo" and the "pectel t2" mean please?
Old Oct 5, 2011 | 10:58 AM
JonnyBravo's Avatar
JonnyBravo
Atmo YB is just a naturally aspirated version of the turbo engine, far from ideal as the engine was never designed to be NA so bits need changing to be suitable, they are strong engines though but I'd have a xe over one any day of the week as their far better suited, I suspect the people that use one are only purists or classed where they have to run a Ford engine as you don't get much for your money.
Pectel T2 is a ecu, on a NA engine most ecu's will do, T2 is expensive and unless you have bundles of money to throw at it I can't see the point in using one, basic MBE would run a atmo YB perfectly, only issue with the Honda engine is that you need to use a ecu that can activate the Vtec although most cheap stuff will happily do that these days.
So anyway I'd be using a Honda S2000 engine personally.
A guy on Turbosport just had his engine dynoed at over 270hp with 170+lb ft
Spec is stock engine, tb's, dry sump, billet flywheel and custom manifold although stock one is very good.
FAR more reliable than anything else for the money, you can keep them on a wet sump but clearance can be a issue as its a tall engine
The other bonus is that most of the engine packages come with a 6 speed box that can actually take high rpm unlike anything that you will bolt to a Yb engine ( or xe etc. )
I priced up every option when I was doing mine and the Honda as a package was several thousand pounds cheaper than similar powered engines but wouldn't suffer from hard use making a much better engine to use long term.
Old Oct 5, 2011 | 11:46 AM
J1mbo's Avatar
J1mbo
B1mbo
Depends who's doing the work, for t2 you can pick up for 4-500 second hand, 625 brand new and a basic loom would do, so not silly expensive, just reliable and for us nice to map.
James, I bet a atmo yb would be cheaper to do between 200-250bhp then a Honda, as no need for a dry sump, other wise most bits are the same. And it can be done on a 205block engine which you can pick up for pennies
Old Oct 5, 2011 | 12:47 PM
JonnyBravo's Avatar
JonnyBravo
I bet you can't supply a 250hp na yb for as much as a s2000 engine, don't forget they have 240hp as standard and that's no more than Ł2500 with a gearbox and everything, full running package. Fit a ecu and you can massively improve the mid range over standard.
I'll take a guess that a yb head supplied and ported with throttle bodies is atleast a couple of grand and that's not Inc the valvetrain, pulleys, pistons, ecu, gaskets oil pump and bearings. Then you have a gearbox to buy so that's another grand or more.
Not knocking them as I think their great but having been down the route of doing something like this nothing is in the same league as the Honda engine for the money, not even close.
It's the same with pintos, 200hp is a lot of money ! A stock Xe on tb,s and the mildest Kent cams gives a very reliable 200hp and the core engine is Ł200 "if" it ever went wrong.
Ford engines generally are very expensive to modify, atleast in na trim
Old Oct 6, 2011 | 04:53 PM
M16NTE's Avatar
M16NTE
id go duratech mate, thats wot im going to do with my mk2.. a standardish engine, cams and throttle boddies will get 200bhp...
Old Oct 6, 2011 | 05:15 PM
cozmeister's Avatar
cozmeister
More boost Igor!
There's only one engine for a Mk2 Escort, in my humble opinion: the BDA
Old Oct 6, 2011 | 05:17 PM
gouch1's Avatar
gouch1
if i was to build a mk2 i would use the lexus is200 engine box a is2oo can be bought for as little as 800 now and can produce that power mapped and they are reliable
Old Oct 6, 2011 | 06:39 PM
rs clint's Avatar
rs clint
insane
bda engines cost between 20 to 25 grand good luck with that
Old Oct 6, 2011 | 08:05 PM
cabriolet's Avatar
cabriolet
2.0 litre zetec keep it ford keep it real
Old Oct 6, 2011 | 08:10 PM
massivewangers's Avatar
massivewangers
BDA is the daddy, but expensive.
Would be a 2.0 Duratec for me I think.
Old Oct 6, 2011 | 08:28 PM
blue oval 24v's Avatar
blue oval 24v
was made for it but the v-tec would be very cool too
Old Oct 6, 2011 | 09:13 PM
Albino Deano's Avatar
Albino Deano
FROZEN WHITE FRS No2676
2.4 warrior twincam pinto 205 block 302 bhp on jenvey throttle bodys dta management its all about the torque honda s200 rev all day but no torque.
http://youtu.be/FfpCVpJHWyQ
http://youtu.be/gVrSnUxGEy8
Old Oct 7, 2011 | 09:05 AM
XRT_si's Avatar
XRT_si
Having seen shed loads of Mk2 Escorts and engine options my money would go with a VTEC engine too
Old Oct 8, 2011 | 09:32 PM
d8vyr's Avatar
d8vyr
lexus is200 is a six cylinder engine mated to a 6 speed box.
best to go for the import version of the lexus, it`s called an altezza rs200, 210 bhp standard and quicker than the lexus and still retains the 6 speed alloy box
Old Nov 19, 2011 | 02:42 PM
melspec1's Avatar
melspec1
ford should be keep't ford. not jap! wots next hotpoint washer motors.
Old Nov 19, 2011 | 03:13 PM
boy-racer-1's Avatar
boy-racer-1
i would not even bother with cosworth in na form if you want a bhp figure over 180bhp as its really expensive and not worth the amount you put in for the bhp you get back, lots claim to have hit 200bhp with cosworth na form easily but truth is they have spent thousands and are only just hitting 180bhp, if i was you id stick to something simple like a 2.0l zetec silvertop, everything you need to put that engine in youe escort is on this website and im sure they will give you plenty of advise when it comes to buying
http://www.retro-ford.co.uk/shop/catalog
Old Nov 19, 2011 | 04:51 PM
WongRS's Avatar
WongRS
Millington diamond series 3 should do the trick
Old Nov 19, 2011 | 04:56 PM
RC4's Avatar
RC4
http://www.youtube.com/watch?v=R3xFUcnJgWA
as above!!!!!! no alternative!!!
Old Nov 19, 2011 | 04:59 PM
WongRS's Avatar
WongRS
Mr Collins, rather rapid that one is.
Old Nov 19, 2011 | 05:10 PM
rs clint's Avatar
rs clint
insane
yeah phil collins has it re built every rally 25 to 30 grand engine what a monster though
Old Nov 19, 2011 | 05:11 PM
WongRS's Avatar
WongRS
not surprised the way he drives it!
Came to our last car club annual meal as a guest speaker.
Old Nov 19, 2011 | 05:17 PM
rs clint's Avatar
rs clint
insane
met him on rally day at coombe sound bloke he usualy crashes out big style
hopper350
Sep 4, 2015 12:53 AM
Sep 3, 2015 10:49 AM
