Sierra brake help
Old Oct 3, 2011 | 07:40 PM
N.Saph's Avatar
N.Saph
New Ford sierra owner
Default Sierra brake help
car is a 1989 1.6 classic
changed front discs an calipers to 4x4 twin cam calipers
put all on
tried to bleed
pumped a few times then pedal hit the floor but now wont stiffin up again?
put old caliper back on and the same
took off an pumped an its not even dripping?
plenty of fluid to an was grand before changing
any ideas
Old Oct 4, 2011 | 12:19 PM
martysmartie's Avatar
martysmartie
Sounds like you may have damaged the M/C, did you push the pistons back on the new calipers?
Not that it will make any difference but assuming it's a conventional servo have you tried starting the engine to "Re charge the servo" so to speak?
Martin
Old Oct 4, 2011 | 02:08 PM
N.Saph's Avatar
N.Saph
yea tried startin the engine
no difference
anyone got a correct guide on how to bleed them?
im going to try get a M/C now an retry them
is there any order you do them?
car started or off?
brake fluid cap on or off?
Old Oct 4, 2011 | 06:10 PM
martysmartie
If it's a NON ABS model, you can bleed in the conventional "Two man" method, start with the wheel furthest away from the M/C, so in the case of these cars thats the nearside rear, working your way toward the M/C.
i.e. offside rear, nearside front, offside front, leave the cap on, engine dosen't need to be running either.
Martin
Old Oct 4, 2011 | 06:30 PM
N.Saph's Avatar
N.Saph
ah ok
i got a M/C there
so start pass rear, pass front, rear driver an then driver front?
Old Oct 4, 2011 | 06:33 PM
martysmartie
No furthest away to the closet, so, NSR, OSR, NSF, OSF.
Martin
Old Oct 4, 2011 | 06:51 PM
N.Saph's Avatar
N.Saph
Martin
ah got a mechanic to take the car an install the M/C and bleed the brakes
yatta
May 21, 2016 10:31 PM
155lee
Oct 27, 2015 04:55 AM
focus2351
Sep 9, 2015 09:33 PM
cossirob
Sep 3, 2015 09:17 PM
