3 bar MAP sensor
Old Oct 2, 2011 | 05:48 PM
franssusilo's Avatar
franssusilo
Default 3 bar MAP sensor
Hi everyone...
Just need some information regarding tuning the ford escort cosworth to gain more hp..
I have seen the most common mods is by getting -31 actuator, 803 dark green injector, fuel pump and 3 bar MAP sensor, then increase the boost.
My question is : if I already use a haltech (fully programmable aftermarket ecu) to replace the standard ECU and already installing a haltech boost control solenoid to increase the boost to 1.3 BAR, do I still need to get the 3 bar MAP sensor? ( I mean does the 3 bar MAP sensor only necessary if I still use a standard ecu and using a chip to increase the boost )
Hope to get great informations...thank you...
Old Oct 2, 2011 | 06:18 PM
oldford's Avatar
oldford
?? No reply at all ??
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
timsrs
Nov 13, 2018 11:48 AM
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
jay030787
Sep 25, 2015 01:38 AM
