Pic Request: Std DV set on FRS
Old Sep 27, 2011 | 09:25 PM
Sticky.'s Avatar
Sticky.
Default Pic Request: Std DV set on FRS
Can you show me your pics of the standard (recirc) dump valve set up on a Focus RS mk1 please.
Old Oct 2, 2011 | 01:47 PM
Zetecfiesta's Avatar
Zetecfiesta
will pop outside and take a pic mate.
Old Oct 2, 2011 | 02:04 PM
Zetecfiesta
here are the pics, im assuming that you know its located under the battery:
So its on this lower pipe:
Hope this helps
Old Oct 6, 2011 | 08:47 PM
Sticky.'s Avatar
Sticky.
Thanks mate...
Old Oct 8, 2011 | 10:11 AM
Zetecfiesta
not a problem!
Old Oct 8, 2011 | 02:15 PM
Sticky.'s Avatar
Sticky.
Can the Recirc DV be situated at the top of the intercooler or does it have to go into the bottom hose?
Old Oct 9, 2011 | 09:21 AM
Zetecfiesta
bottom hose only i believe, if its fitted at the top its only atmospheric dumpvalves that go on that pipe.
Old Oct 9, 2011 | 12:23 PM
Sticky.'s Avatar
Sticky.
Thanks mate, one last question?
Where does the hose get routed, is it over the gear box?
Old Oct 9, 2011 | 03:14 PM
Zetecfiesta
erm im not sure, i will go and look!
Old Oct 9, 2011 | 03:33 PM
Zetecfiesta
just gone and looked and it comes off the righthand side loops down then over the gearbox, runs along side the coilpack and then attatches to the outlet on the top back left of the chargecooler box.
does that make sense?
Old Oct 9, 2011 | 06:53 PM
Sticky.'s Avatar
Sticky.
Sort of mate.
Old Oct 11, 2011 | 11:23 AM
Zetecfiesta
did you get it sorted?
Old Oct 11, 2011 | 06:48 PM
Sticky.'s Avatar
Sticky.
Yes sorted it, could do with a proper OE hose thou.
Thanks for your help mate.
Old Oct 11, 2011 | 10:19 PM
Zetecfiesta
just get the roose silicone kit mate!
3drRich
Sep 13, 2015 07:32 PM
FlashRS
Aug 30, 2015 08:07 PM
Steve Escos
Aug 24, 2015 07:56 AM
Zoggon
Aug 10, 2015 10:39 AM
slammedorion
21
Aug 6, 2015 11:38 AM
