fuel pressure reg aeroquip
has anyone aeroquiped a standard cosworth fuel reg before and if so how did you do it in just sorting out my fuel system so im going to do away with all the jubilee clips
nice one but looks like ive sorted it now as i popped over to andy robinson race cars after work as hes modding my fuel rail by brazing on too aero fittings as im going to do the hole fuel system and as im going to mount the reg some where else it was the fixed tail i was having probs with but hes going to weld a fitting on to that as he says he can do it with out damaging the inside
and as he stocks all the fitting and hose hes going to sort the same type of set up as in that pic for the removable one
ive welded several, the first i tried just leaked, after several hours of differant processes, mig, tig, gas, they all leaked, when you file off the outer plated coating you will see the cooper lining, how do you thing the injector cups are sealed in? they are not welded
they are compressed into a copper lining hence they seal.
im sure Andy will be able to come up with a method to weld it.
I've silver soldered loads in the past and never had one leak...although silver solder is a non penetrating process, we have used it on small stainless jobs up to 60 bar and not had an issue....
the too tails i cut off that the original hose gos over had no lining on them anyway lol they were stainless so brazeing to them will be fine i will no later anyway as i will be picking it up
nipper.1
Ford KUGA
12
May 30, 2022 07:39 PM
JK12
33
Apr 26, 2021 12:09 PM
wheelwizardrefurbs
Sep 24, 2015 08:35 PM
Dubs44
Sep 19, 2015 06:31 AM
