getting a tyre off at home?
Old Sep 20, 2011 | 08:24 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
Default getting a tyre off at home?
how hard is it to remove/refit a tyre diy at home?
reason i ask is cos if it snows early like they are saying i have a set of snow chains, but dont want to shag the alloys so will use them on a pair of steelies from the scrappers, but they all have fucked tyres on.
i have 3 spare pirelli p6000 at home home with decent tread so will bang one of those on and just take it for balancing.
it cant be that hard can it, using levers etc not worrying about the rim.
Old Sep 20, 2011 | 08:45 PM
Moonstone Steve.'s Avatar
Moonstone Steve.
Your going to need big arms
Steve
Old Sep 20, 2011 | 08:47 PM
Mark 3D's Avatar
Mark 3D
Moderator
Steve
and 3 spoons
Old Sep 20, 2011 | 08:52 PM
stuboy's Avatar
stuboy
i got an older version of this..
http://www.tyre-equipment.co.uk/acat..._Breakers.html
Old Sep 20, 2011 | 08:54 PM
massivewangers's Avatar
massivewangers
Just use a tyre fitting place
Old Sep 20, 2011 | 08:56 PM
dojj's Avatar
dojj
Resident Wrestling Legend
chuck them a tenner to get them swapped over and no recipt, they'll do it in their spare time and be happy for it
much better than bending all your cutlery
Moonstone Steve.
Originally Posted by markyd3
and 3 spoons
My mum had many bent spoons in the draw trying to get the tyres of my Grifter lol.
Steve
Old Sep 20, 2011 | 09:07 PM
DanW@FastFord's Avatar
DanW@FastFord
Spelling Club King!
If you do try it, please film it, and post it up!!
Old Sep 20, 2011 | 10:50 PM
stevieturbo's Avatar
stevieturbo
C**t
You can buy second hand wheels and tyres so cheap, why would you even bother trying ?
Or just buy snow tyres
Old Sep 20, 2011 | 11:26 PM
Psycho Warren's Avatar
Psycho Warren
Carbon Crazy
by a set of snow rally tyres and pretend your mcrae
Old Sep 21, 2011 | 06:18 AM
Fordmad!'s Avatar
Fordmad!
Ive got the tools for the job but doing it without scratching your wheels is nearly impossible!
I only do it on me van. Just go to the garage!
Old Sep 21, 2011 | 06:35 AM
mk2 escort boy's Avatar
mk2 escort boy
Where abouts are you? I could do it if your not to far away ,I was a truck tyre fitter for years and we fit those by hand no machine so car Tyres are a peace of piss as long as there not low profiles or alloys can do alloys but there's a chance it might bend
Old Sep 21, 2011 | 07:06 AM
SteveB's Avatar
SteveB
and with the £250 from "You've been framed" he can pay for a new set.....lol
Old Sep 21, 2011 | 07:29 AM
Rick's Avatar
Rick
Lol, why would you even try this?! The tyre forms a seal to the rim which is not easy to break.
Old Sep 21, 2011 | 08:33 AM
fraser9764's Avatar
fraser9764
I've done it before, i had a pile of old steelies with tyres at the bottom of the garden and my mum decided she wanted to use the tyres as plant pots
I used a bottle jack under the work bench in the shed to push down on the tyre and break the bead, then some big tyre leavers to pull the tyre off. Then i suppose, as per haynes, refitting is the reverse of removal.
Old Sep 21, 2011 | 09:12 AM
CalibreDan's Avatar
CalibreDan
Got a few tyres off at home - Easiest way I've found is to get the wheel under a jacked up car, bit of wood on the tyre, and lower the car down on top. Takes a bit of effort to get the tyre off after that but nothing too bad.
Loads of videos on Youtube of rednecks getting tyres off in all exotic ways
Old Sep 21, 2011 | 09:36 AM
oibren85's Avatar
oibren85
If in Doubt Flat Out...
You might bend the alloy by doing by hand. Are you He-man......?
Old Sep 21, 2011 | 10:08 AM
mk2 escort boy
Ha ha I wish the size of the lever may bend the lip of the rim
Old Sep 21, 2011 | 10:09 AM
Mark 3D's Avatar
Mark 3D
Moderator
Steve
LOL im so glad someone "got it" yeah same with me but i had a Chopper
Old Sep 21, 2011 | 10:37 AM
ozmk1cos's Avatar
ozmk1cos
Drive over edge of tyre, this will break the bead. Get some decent levers and remove.
You dont have much choice if your 4wdriving
Old Sep 21, 2011 | 05:10 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
cos last time i dont that the cunts ripped me off and chaged me double
cos i have 3 tyres with decent enough tread on them
near swindon mate, just std steelies not worried about any rims
angle grinder to get old ones off.... easy enough
what the fuck do you lot think was used before they invented tyre removing machines?
Old Sep 21, 2011 | 05:19 PM
RichieST's Avatar
RichieST
Had proper tyre levers and a hand press for breaking beads at my old job, even then it was fucking difficult, if it's a low-ish profile tyre then you have no chance. Plus even if you get the new tyres on you will need to get them balanced anyway. You get over to corsham much? Take them into corsham tyres, they charge £1 per inch to swap tyres, I should imagine they'll do it cheaper if the wheels aren't on the car.
Old Sep 21, 2011 | 06:38 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
its getting them back on thats going to be the hard part. cut old tyres off before thats no drama.
im talking a 195/50/15 pirelli, so not low profile onto a steel rim that can get scratched etc not a brand new of rims.
my dads mate does it with levers and i think my mate has got some i could borrow.
then just need balancing.
Old Sep 21, 2011 | 06:44 PM
Rick's Avatar
Rick
fitting the tyre costs very little, it's the balancing that is expensive, as they can't use lead weights anymore
Old Sep 21, 2011 | 06:48 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
no, its the fuckers fitting tyre you supply that costs a lot!
i know as i had a set fitted for combe in july and got fleeced!
they quoted me £10 a tyre to fit, x 5 tyres...
then decided not to charge me that it ended up double. and i was not fucking happy...
so ill DIY thanks!
as they will only be going on if it snows i may not even bother to balance them as i wont be going fast!
Old Sep 21, 2011 | 07:30 PM
mk2 escort boy
Hi mate I live 20mins from Swindon , pewsey pm me and I can do it for you
Old Sep 21, 2011 | 07:52 PM
gjh's Avatar
gjh
Getting it off is tricky, getting it back on is just a case of a load of lighter fluid and a match.
Old Sep 21, 2011 | 07:59 PM
Rick's Avatar
Rick
so ill DIY thanks!
your post makes no sense!
Old Sep 21, 2011 | 09:54 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
awesome, ill let you knw when i get hold of some wheels cheers mate.
so you just have a rim, a tyre, throw a load of lighter fuel over them both and chuck on a match??
doesnt the tyre have to be on the rim for that to work lol
ok:
in july this year i took my puma on track at rs combe, bought a set of 4 tyres off ebay and got quoted a price of £10 per wheel to have the tyres fitted. i said while they were doing it to change the tyre off the spare steelie as that was fucked and replace with the best of the p6000 they took off.
so i was expecting a bill of £50
i go back to collect the car later that day to be told that he decided not to charge £10 per wheel, and that they had charged me an hour labour, plus £5 a wheel balancing - plus VAT = just short of £100.
i was then pretty fucked off having received no phone call to tell me that this is what they were now going to do, felt fleeced and will not be using them again for anything...
so ill DIY thanks!
in future i will endevour to do as much as i can myself, not paying some silly cunt to rip me off
as low speeds will be used while driving in snow, balancing may not be required as i wont be going fast enough to cause any issues
understand now?????
good!
Old Sep 21, 2011 | 10:05 PM
stevieturbo
C**t
Jesus, even Kwik Fit wouldnt charge that sort of money for a changeover !
Old Sep 21, 2011 | 10:09 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
i think it was cos i didnt get the tyres from them, so they bumped it up!
a lot of tyre fitters dont like fitting tyres they dont supply
Old Sep 21, 2011 | 10:14 PM
stevieturbo
C**t
True, but there are smaller tyre places all over the country that are usually friendly enough for that type of thing.
Hell, even the big places here wouldnt charge that much.
Old Sep 21, 2011 | 10:24 PM
dojj's Avatar
dojj
name and shame
that's properly fleecing you
Old Sep 21, 2011 | 10:30 PM
kaking1982's Avatar
kaking1982
thats cheap it cost me £15 a tyre to be fitted for my st wheels
Old Sep 21, 2011 | 11:08 PM
kaddyT4's Avatar
kaddyT4
depends on size mate 195/65/15 205/55/16 things like this you can do them! 225/40/17 225/45/18 ect... things like this forget it, "and i love my self as a tyre fitter" lol
Old Sep 21, 2011 | 11:24 PM
phil_focus's Avatar
phil_focus
ok:
so ill DIY thanks!
understand now?????
good!
should have told them to put it all back the way it was as they were not authorised to do the job for that much!!!!
having said that i think round my way its abot £15 a wheel to swap and ballance.
Old Sep 22, 2011 | 07:37 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
i wont be going back to the place, a small garage right opposite where i work so was very handy and a lot of people from work use them. but i will not any more and told others about it.
worked out at almost £20 a tyre, so was not cheap!
Old Sep 22, 2011 | 07:43 PM
1.9 xr2 on 40's's Avatar
1.9 xr2 on 40's
st170 breaking
the manager of my local place is cool with doing them cash, all goes in the tea and biscuits pot
i used ot have em removed to scrap wheels for £1 each, ive done it with a grinder but its just not worth doing it anyway but propper
Old Sep 22, 2011 | 07:45 PM
1.9 xr2 on 40's
st170 breaking
you guys are paying some mad prices
i think a fiver is too much, if its a puncture i wont pay over a tenner
Old Sep 22, 2011 | 07:48 PM
saph4be's Avatar
saph4be
I need up charge more!
