oil pressure problem, my dads car.
Old Sep 16, 2011 | 03:39 PM
Mk4 Lew's Avatar
Mk4 Lew
Default oil pressure problem, my dads car.
hi lads
can anybody shed any light on why a engine would loose oil pressure after a top end rebuild.
any help appreciated
Old Sep 16, 2011 | 03:52 PM
R4N SS's Avatar
R4N SS
something must be fooked
you done a compressions test? check the plugs first tho?
Old Sep 16, 2011 | 04:11 PM
Mk4 Lew's Avatar
Mk4 Lew
forgot to add, its still in the garage where the work has been done, had a new head gasket on and the mechanic dosnt know the problem
Old Sep 16, 2011 | 04:14 PM
pee vee's Avatar
pee vee
what car is it?
if it deffo was TOTALLY fine, just before the rebuild.
the mechanic dropped some shit down the oil ways, and either blocked the pick up, or
has fukked the bearings.. ?????
water not drained out fully, and has got in with the oil when head was taken off??? spose that would make the oil go like mayo though,
lol
Old Sep 16, 2011 | 04:24 PM
Mk4 Lew's Avatar
Mk4 Lew
chevrolet tacuma mate, oil pressure problems before rebuild, pick up cleaned, engine flushed, head skimmed and had a new head gasket. the oil pressure is fine on tick over but drops when the engine is under load.
Old Sep 16, 2011 | 04:45 PM
Lovely GM quality lol. Has the oil pump fookes up.is the head gasket on the right way round.You couls put fiat punto head gaskets on both ways but 1 way would block the oil way.
Old Sep 16, 2011 | 04:46 PM
Bastard didnt read your last post lol.The oil pump might be nackered.
Old Sep 16, 2011 | 04:51 PM
Mk4 Lew's Avatar
Mk4 Lew
it went in for a new oil pump mate but 'apparently' its fine
Old Sep 16, 2011 | 04:52 PM
pee vee's Avatar
pee vee
i'd take it back in then.. as the problems didnt arise suddenly after the head rebuild..
Old Sep 16, 2011 | 04:54 PM
martysmartie's Avatar
martysmartie
I would go with the oil pump, it may even be something to do with the relief valve.
Lol at the GM comment, Cosworth had a whole batch of faulty pumps a while back.
Martin
Old Sep 16, 2011 | 04:55 PM
Mk4 Lew's Avatar
Mk4 Lew
its still in mate
Old Sep 16, 2011 | 05:16 PM
saph4be's Avatar
saph4be
Change mechanic lol
Old Sep 16, 2011 | 07:08 PM
R4N SS's Avatar
R4N SS
Either something is blocked or the oil pump is fooked
Old Sep 16, 2011 | 07:30 PM
Rax's Avatar
Rax
Thats my diagnosis too,from my keyboard like
Old Sep 16, 2011 | 07:35 PM
escoskmv's Avatar
escoskmv
oil pump, if not id say its a strip down an inspection bud
Old Sep 16, 2011 | 07:37 PM
Mk4 Lew's Avatar
Mk4 Lew
cheers guys, it was ment to go in for a oil pump in for it with the rebuild the the mechanic said it was fine
Old Sep 18, 2011 | 02:35 PM
Mk4 Lew's Avatar
Mk4 Lew
any other ideas? chevrolet told my dad its ither the oil pump or the engine bearings without checking it themselvs, so the mechanic is checking the engine barings.
Old Sep 18, 2011 | 03:25 PM
bigjohn0's Avatar
bigjohn0
Did they change the pressure switch ? seen it done before
Old Sep 18, 2011 | 04:50 PM
bunnymofo's Avatar
bunnymofo
im puting my money on either pressure relife valve, or that lewid did it himself and isnt letting on as he fuckedup ?
Old Sep 18, 2011 | 04:53 PM
Mk4 Lew's Avatar
Mk4 Lew
shut it sandy
Old Sep 18, 2011 | 04:59 PM
bunnymofo's Avatar
bunnymofo
if the spring in pressure relife valve is worn / weakend, then there wont be enough pressure to open it on idle, but when revved theres enough pressure to open it bit its opening too far as its weakend, that could cause it.
Old Sep 19, 2011 | 01:25 PM
Mk4 Lew's Avatar
Mk4 Lew
right, just been to the garage. hes fetching a new oil pump tomorrow
Old Sep 20, 2011 | 02:24 PM
Mk4 Lew's Avatar
Mk4 Lew
just got home, the car is parked outside and the oilpump was the problem
Old Sep 20, 2011 | 02:33 PM
bunnymofo's Avatar
bunnymofo
good
now tell your dad not to let u tinker with the car again
Old Sep 20, 2011 | 02:35 PM
Mk4 Lew's Avatar
Mk4 Lew
Old Sep 20, 2011 | 02:40 PM
bunnymofo's Avatar
bunnymofo
Old Sep 20, 2011 | 02:55 PM
saph4be's Avatar
saph4be
Just ring me next time
Old Sep 20, 2011 | 03:00 PM
Mk4 Lew's Avatar
Mk4 Lew
lol, will do matey. the monkey had to go to mansfield to pick up the part today
Chas
Sep 21, 2015 08:57 PM
Adam-M
Aug 26, 2015 05:53 PM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
mrmann
Aug 20, 2015 11:24 PM
tankybaby66
Aug 9, 2015 07:13 AM
