Wheels and Tyres Wheels and Tyres for all Ford's
Mk5 Fiesta alloy sizes
Old Sep 16, 2011 | 09:10 AM
Mk5Fiesta:)'s Avatar
Mk5Fiesta:)
Smile Mk5 Fiesta alloy sizes
Hi All,
I have a 2000 1.25 LX (one of the best for the year I think) and it has the old 13" steel wheels atm. Does anyone know if I can use Borbet 14" Alloys - stud diameter of 108, 38 offset, 6j rim width?
If so, as long as the stud size is 108 can I just stick on most tyres up to 16" rim size?
Cheers,
Nick
Old Sep 16, 2011 | 09:26 AM
CosworthGuy's Avatar
CosworthGuy
3dr Cosworth owner
Is say you'll be fine with the wheels you mention. studs the same. offset is only 3 mm out. All depends on the size of the tyre
Old Sep 16, 2011 | 09:53 AM
zetec-Sam's Avatar
zetec-Sam
neeeeeeeeooowmmmm
Please lower it if you fit alloys!
Old Sep 16, 2011 | 10:08 AM
Mk5Fiesta:)
Haha - yes could do - but my concern is that the wheels still turn....
I also need to put the white racing stripe on it.
On another not, I was on Parkers and my 11 year old 1.25 has a 0-60 of about the same as a 3 year old 1.6 focus... Nuts!
Old Sep 16, 2011 | 10:09 AM
Mk5Fiesta:)
Thanks - I need to check what is on the wheels already as need to agree to purchase...
Old Sep 16, 2011 | 10:10 AM
zippyobrien's Avatar
zippyobrien
They'll fit fine with some 185 55 14 tires.
I'm running 16x 7 et25 ( that's low) with 195/45/16 and there ok.
Old Sep 16, 2011 | 11:00 AM
Mk5Fiesta:)
Perfect - Thanks Zippy
Old Sep 16, 2011 | 03:08 PM
martysmartie's Avatar
martysmartie
Hardly a surprise considering the size and weight bonus your car has!
Martin
Old Aug 27, 2012 | 01:23 AM
molliwopp's Avatar
molliwopp
Because Ford.
Ok i have an 02 mk5 fiesta. I have bought some 195/45/16 alloys with an et of 41.5 will they fit my car properly and if i could lower it alittle how low could i go without any rub or arch work?
Old Aug 27, 2012 | 08:17 AM
zippyobrien
Will be fine.
As its a non zetec s shell you may have to roll the rear arches ( zetec s are rolled from the factory)
I had a 1.25 track car with a puma lump.
That was down 80mm on 195/45/16 tires and didn't rub.
Old Aug 27, 2012 | 05:37 PM
molliwopp's Avatar
molliwopp
Because Ford.
Thanks, Im trying to avoid rolling the arches because the paint on the back isnt very healthy. Could i go to say 30mm without any arch work on some 195/45/16 et 41.5
Old Aug 27, 2012 | 05:48 PM
zippyobrien
Yh as I said I was down 80 mm on et 37 195/45/16
Old Aug 27, 2012 | 05:51 PM
molliwopp's Avatar
molliwopp
Because Ford.
Ok. Well mine a freestyle not a zetec s so obviously has less clearence. Could i blind buy 30mm or 40mm lowering springs or to be safe shud i fit the alloys first. Im worried 41.5 et are going to sit too far into the car. Is fittin 5mm spacers a good idea or not?
Old Aug 27, 2012 | 07:15 PM
zippyobrien
Just try it on. Mine was a 1.25 freestyle shell.
The only bit that rubbed even with 8j wheels was the tear bumper hanger
Old Dec 12, 2012 | 12:03 AM
molliwopp's Avatar
molliwopp
Because Ford.
Hi, long time no post. My fiesta is looking nice and wanted to know if fitting some 6mm front and 10mm back universal spacers would be a bad idea.. Finding hub spacers at these sizes prove tricky and expensive.
Old Dec 12, 2012 | 04:39 AM
STeve's Avatar
Super Moderator
for the front upto 10mm on std wheels works well and rears you can go to 20.5mm but I would go with axle spacers on rear not spacers and they only cost around £28
Old Dec 12, 2012 | 08:06 AM
molliwopp's Avatar
molliwopp
Because Ford.
I have some mk7 titainum wheels on 6.5j 41.5 et so poke a tiny bit more than standard wheels is a universal 10mm spacer safe without lengthening the bolts? I never have any real weight in the car. The bolts from a mk7 would, i assume be stronger due to the mk7 fiesta being heavier
Old Dec 12, 2012 | 08:55 AM
STeve's Avatar
Super Moderator
I think any spacer over 3mm really you need to lengthen bolts on a fez, I dont trust universal spacers period, they either need to be a solid disc type or hubcentric style minimum for safety
Old Dec 12, 2012 | 04:10 PM
molliwopp's Avatar
molliwopp
Because Ford.
Ok. Well how much are bolt sets and decent solid disk type spacera? Can you poimt me in the right direction.
Old Dec 12, 2012 | 04:18 PM
STeve's Avatar
Super Moderator
plenty of decent companys out there just stay away from halfords and the like, heres one company http://www.performancealloys.com/whe...ers-shims.aspx but no doubt others have different recommendations, also have bought them from burton power before too which were really good quality http://www.burtonpower.com/wheel-spa...hick-spt5.html
Old May 15, 2014 | 02:47 PM
TKOFFICIALMC's Avatar
TKOFFICIALMC
Ok, thats great information!!!! Shall I assume I can throw on a pair of original escort cossie wheels, directly onto my 1.25 without any further complications???
rex647
Mar 6, 2022 06:20 AM
mondeomark
Alloy wheels and ICE for sale
Sep 27, 2015 09:17 AM
Mk5brown
Sep 9, 2015 12:52 PM
Ade
Sep 7, 2015 05:06 PM
