coil on plug kit on ebay for rs cosworth
thinking about this, that i have found on ebay. after my coil got wet and shit its self. think this is the ansure. my nissan had it and never missed a beat.
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=260852319414&fromMakeT rack=true&ssPageName=VIP:watchlink
en
en
Not sure but I don't think you can't run sequential spark firing off a Weber L series ECU.
If you've got an aftermarket ECU like an Omex or Autoronic you'll be fine.
You might beable to wire them up as wasted spark so you could use the board MSD do.
Rich
Rich
You need aftermarket ecu to run that set up.
I can't understand why people have so many problems with the std setup :/ the wasted spark kit is totally unnecessary and adds more problems than it supposedly fixes and makes problem solving difficult as it will always be your fault
Then there is the rev counter issues.
I believe COP is mainly beneficial for high revving engines, perhaps explains why Hondas have it, plus they have used it for years, all Civic EP3'S have it!
Martin
Agree with what you've said though, it's always your fault!
My car runs 071s with .7mm gap which is the same as I have seen recommended to run on the ws kit
no it's YOUR fault!!! A run of the mill stg3 t34 cossie doesnt need wasted spark it won't make it any faster and the standard ignition system is more than up to the job
Pmsl I see it on here all the time
and I "experienced" it 9 years ago it deviated slightly in the middle but it has now gone full circle back to the old days
And even my mrs "experienced" it so it's not me
I also have seen the starting issue, but naturally - you can guess who's fault that was
probelem with batch firing the coils in in the dwell time ,
aparently someoen was working on a setup for l8 but never heard anthing ,
im planning to run it on mine , with omex ,
if will gets me a price on a ecu lol
I'm sure its been done before on a YB with wasted spark but obviously the coils would be working twice as hard, I did this on a VAG engine and it worked fine but I did get through a couple of coils and in the end reverted back to a Ford coil pack which doesn't give any problems. I'd only go plug top coils if you can fire them sequentially.
Rich
wasted spark could run COP, but no real gains to be had.
i have plans for COP on my ZT due to MS being ready for them as sequential ignition.
just cuts out HT lead failure really, and perhaps a cleaner spark.
I'm pretty sure that the coils I have put put out much higher KV than the Ford coil pack and getting rid of the leads has to be the way forward so I'd say there are real gains! Plus plug top coils give out less electrical noise..
borboyous
Aug 22, 2015 11:17 AM
Anutternutter
Aug 21, 2015 06:07 PM
Aug 14, 2015 07:29 AM
Zoggon
Aug 10, 2015 10:39 AM
you obviously have similar experiences as me
