Bizzare paint problem
Old Sep 10, 2011 | 03:37 PM
lukeytheduke's Avatar
lukeytheduke
Default Bizzare paint problem
hi all, i left my car last week and its fine. Today i went back to it as it looked like hundreds of 1-2mm round rust spots all over it. I actually nearly cried now i.ve tried polishing out scrubbed it like a bitch for hours and its get the most of but if u look closely they are still there. Has anyone come across this before? At first i thought it was fallen pollen from a tree but i guess that would wash out, its a yellowy brown colour just like rust. Someone please help cheers luke
Old Sep 10, 2011 | 03:43 PM
pacificzetecturbo's Avatar
pacificzetecturbo
Default car
Has anyone been grinding near it?? that would cause that problem.
Old Sep 10, 2011 | 03:46 PM
Retro Al's Avatar
Retro Al
RWD IS KING
I see this on cars parked next to railway tracks,get some ironx it will remove it no problem
Old Sep 10, 2011 | 03:51 PM
lukeytheduke
no but i was working on the hole in the roof for antenna a week before. Where can i get this ironx thing from mate. Its a white car so it really shows up
Old Sep 10, 2011 | 04:17 PM
Retro Al's Avatar
Retro Al
RWD IS KING
This will do the job http://www.polishedbliss.co.uk/acata...decon-gel.html if it is metal contamination, spray it on and any contamination will turn purple then rinse it off
Old Sep 10, 2011 | 04:25 PM
lukeytheduke
cheers al. I.ve polished the worsed of so its nice and smooth but the rust colour circles are still there
Old Sep 10, 2011 | 04:29 PM
lukeytheduke
will 1ltr surfice for a few bits on roof and boot lid?i dont fancy paying 40quid for next size up
Old Sep 10, 2011 | 05:11 PM
Retro Al's Avatar
Retro Al
RWD IS KING
You wont even do half that m8 1ltr will last you ages,you need to get a spray bottle to go with it and just mist it on,heads on bottle dont last long the product will eat it away after a few weeks
Old Sep 10, 2011 | 05:20 PM
Rick Astley's Avatar
Rick Astley
Never gonna give you up!
It's called industrial fallout, a good polish will get rid.
Old Sep 10, 2011 | 05:39 PM
andy escos's Avatar
andy escos
or you could try this i have used it in the past & got it from one of the big boots chemist
http://en.wikipedia.org/wiki/Oxalic_acid
http://www.amazon.co.uk/Oxalic-Acid-...ef=pd_cp_diy_2
Old Sep 10, 2011 | 05:48 PM
lukeytheduke
Did it work mate?
Old Sep 10, 2011 | 05:51 PM
lukeytheduke
It didnt come of with autoglym SRP and i was polishing and scrubbing all afternoon
Old Sep 10, 2011 | 06:19 PM
opposite lock's Avatar
opposite lock
Definately try the ironx , or maybe a purpose paint cleanser . SRP may well not have enough cut to it to fully remove the marks
Old Sep 10, 2011 | 06:22 PM
andy escos's Avatar
andy escos
Originally Posted by lukeytheduke
Did it work mate?
i used to work in the car repair trade & it worked every time
Old Sep 10, 2011 | 06:26 PM
Rick Astley
I said a good polish
Old Sep 10, 2011 | 06:37 PM
lukeytheduke
cheers boys i'l look into them
Old Sep 10, 2011 | 06:45 PM
Sp3no's Avatar
Sp3no
if you have metal particles rusting on the surface of the paint, the last thing you want to do it polish the car, you will be dragging the metal particles all over your paint and creating microscopic scratches which will effect the clarity of the paint, you should clay the car first to remove all the contaminants an bits of metal and only then should you polish it
Old Sep 10, 2011 | 06:55 PM
lukeytheduke
Old Sep 10, 2011 | 06:56 PM
lukeytheduke
car pro iron x says its the step before claying. I.ve never clayed before is it worth it?
Old Sep 10, 2011 | 06:59 PM
lukeytheduke
Too late now funny u mentiond claying as that iron x says u should clay it after. Is it actually worth claying if i wash and wax it anyone
Old Sep 10, 2011 | 07:00 PM
lukeytheduke
anyway *
Paul_RS's Avatar
Paul_RS
If your paint feels rough, clay should take the roughness off
Old Sep 10, 2011 | 07:01 PM
Retro Al's Avatar
Retro Al
RWD IS KING
You dont need to clay before,if you only want to get rid of the metal contaminaiton just use ironx or the wolfs product as per my link,you can use clay to remove it but its a lot harder work and it costs more for a clay kit.
Ive had some iron contamination that was easly removed with claying,ive also had bad cases were claying was a very long process and iron x was far far quicker
Old Sep 10, 2011 | 07:12 PM
lukeytheduke
cheers al i was going to get iron x then clay it after to give a real nice finish but i might wait till x mas to treat myself to a clay kit. If i dont treat this problem now, will it get worse if left?
Old Sep 10, 2011 | 07:19 PM
Retro Al's Avatar
Retro Al
RWD IS KING
It will get worse for sure i would get it off asap and maybe clay it at a later date
Old Sep 10, 2011 | 07:22 PM
Retro Al's Avatar
Retro Al
RWD IS KING
Iron x and the link i gave you for the wolfs is basicly the same
http://www.youtube.com/watch?v=Tg7t0...eature=related
Old Sep 11, 2011 | 11:22 AM
opposite lock
Iron X is used as part of the decontaminating stages usually after claying and paint cleansing if required .
Old Sep 11, 2011 | 03:39 PM
lukeytheduke
Are u sure on the website it says your iron x THEN clay it? Is iron x actually any good though?
Old Sep 11, 2011 | 05:27 PM
opposite lock
Thats what i,m sure i read on DW about this although of course you dont wanna be rubbing dirt around with clay . These iron deposits were trying to remove can sometimes etch themselves very slightly under the actual surface so no claybar will get them. Just be sensible about it, clay after to make sure everything is definately gone yes and if its caked in bad iron contamination then use IX first after your wash process . You dont want to clay a load of 'large' filling about on paint
After claying a bad suface it may well be in need of machine polishing to correct the marks .
Old Sep 11, 2011 | 05:58 PM
lukeytheduke
just ordered the iron x so will hopefully get it done next weekend. Its a shame i cant upload any photo's via my mobile
Old Sep 11, 2011 | 07:20 PM
Madbradz's Avatar
Madbradz
Let us know how you get on, As I have the same! After my car was parked in a carpark, its like someone has been grinding next to it!
Adam
Old Sep 11, 2011 | 07:25 PM
lukeytheduke
ok mate, i would upload before and after picks but im on my phone so i cant. A good old hard wash got the worst of but apparently if u wash or wax it with the rust still on as it will leave tiny scratches all overt the paint.
155lee
Oct 27, 2015 04:55 AM
morg65
Escort MK 5 / MK 6
17
Sep 11, 2015 08:40 PM
routemaster
Sep 7, 2015 05:27 PM
hopper350
Sep 4, 2015 12:53 AM
