Ford Focus (All Models) This forum is for discussion of all things pertaining to the Ford Focus Range that doesnt belong in the seperate ST & RS sections..
Modifying ST170 dash
Old Aug 29, 2011 | 04:15 PM
Mashurst's Avatar
Mashurst
Default Modifying ST170 dash
Anyone know how to modify one of these to work in a standard Focus? i.e. to get the backlights to work without the oil guages fitted? Cheers.
Old Aug 29, 2011 | 04:30 PM
LukeDaisley's Avatar
LukeDaisley
https://passionford.com/forum/ford-f...s-fitting.html
Have a look here.
Old Aug 29, 2011 | 08:23 PM
Mashurst's Avatar
Mashurst
Thanks Mate, tried a search before, but nothing came up.
Bought na inverter from ebay now, just need to figure out how to wire it up {-|
Old Sep 1, 2012 | 03:05 PM
bakerboy18's Avatar
bakerboy18
Default ST170 oil pressure guage fault
ive recently purchased an st170 registered as 1.4 its had full st conversion. i purchased it with a blown head gasket. i replaced the head gasket and cams as i found one cracked, the vehicle would not start. after messing around with the dash to get the dials to work i found that if i leave the oil pressure/temp gauge multiplug off it starts first time. I then found none of my dials work i was told this when i bought it but he said there was a simple procedure of changing a few wires around. i cannot find my way around it has anyone had the same problem... thanks
p.s. sorry for high jacking this thread as i dont no how to start a new one
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
DAZZER
Sep 30, 2015 08:43 PM
Fordmad!
Sep 29, 2015 07:03 PM
Sp3no
Sep 27, 2015 07:23 PM
Marv888
Sep 26, 2015 03:44 PM
