Miss fire
Got a problem that has got worse over last week. When I used set off my S2 used to miss for about 10 secs then drive fine. Now it is doing it all the time. I have no power and it makes a loud noise. Let it warm for a while this afternoon and noticed No.4 exhaust port was not warm. There was also a bit of oil around it. Can anyone help?
What noise is it making? Where is the niose from?
If its just mising on one cylinder then you need to be checking the plugs, leads, dizzy cap, compression. You mean the manifold was not warm
Where was the oil
mine misses when not up to heat and i let it boost over a bar, think its the wafty leads tho cos teh plugs are almost new
look like the leads are off a panda or sumthin, far 2 short
got some replacements to try 2morrra tho
DixieTheKid
11
Jun 6, 2020 11:20 AM
Bailes1992
Sep 19, 2015 02:17 PM
