Ford Focus (All Models) This forum is for discussion of all things pertaining to the Ford Focus Range that doesnt belong in the seperate ST & RS sections..
will it work?
Old Jul 29, 2011 | 08:44 PM
mmikee's Avatar
mmikee
Question will it work?
I know the 2.0 into 1.6 focus has been covered on here many times but I just want to be sure the models and engines i have will swap ok.
The project car is 1998 1.6 mk1 2door and the donor is 2001 2.0 mk1.5? ghia 4 door.I have the complete 2.0 car with all parts available
My queries;
can i fit the aircon from the ghia?
do i have to fit the anti slip control from the ghia?
should i swap the engine crossmember? or will the 2.0 mounts go on the original?
how much of the loom do i need to change? I've been told some of the looms are interchangable,i.e. can plug the engine loom into the existing harness.
Any other hidden pitfalls?
Am I mad or am I about to be driven mad?
Your input would be gratefully recieved,
Mike
JK12
33
Apr 26, 2021 12:09 PM
Rstar_man
143
Jul 20, 2020 11:16 PM
