S2 boost problem
Old Jul 20, 2011 | 06:47 PM
gazzas1982's Avatar
gazzas1982
Default S2 boost problem
Hi peeps don't know if any 1 can held just got my stage 2 upgrade turbo from Cr turbo put it back on my car now it's like there ain't a turbo on it any suggestions some 1 said it might be the bar on the actuator not set properlly but I'm not to sure about actuators any help appreciated
Old Jul 20, 2011 | 06:49 PM
studabear's Avatar
studabear
Are all the hoses fitted with the clips tight?
Old Jul 20, 2011 | 07:05 PM
gazzas1982's Avatar
gazzas1982
Yeah mate
Old Jul 20, 2011 | 07:16 PM
2m1fy's Avatar
2m1fy
have you got a new actuator?
Old Jul 20, 2011 | 08:13 PM
gazzas1982's Avatar
gazzas1982
Yeah mate was supplied with the turbo
Old Jul 20, 2011 | 08:25 PM
stevealien's Avatar
stevealien
10 Year Member
you need to check the preload on the actuator rod mate.
should have about 3 or 4mm pre load,half moon on the hole.
do you have a boost gauge??
Old Jul 20, 2011 | 08:38 PM
gazzas1982's Avatar
gazzas1982
what do you mean by 3 or 4 mm pre load do you mean 3 or 4 mm of thread should be visable of the thread on the bar and no i dont have a boost gauge at the min and what do you mean about half moon on the hole
Old Jul 20, 2011 | 09:20 PM
stevealien's Avatar
stevealien
10 Year Member
where the actuator rod goes onto the wastegate bar,
you need to set the length of the actuator rod so that the hole at the end of it sits halfway across the actuator bar,so the hole is like a half moon.
you should have to stretch the rod to fit it onto the wastegate by about 4 mm.
make sense????
JK12
33
Apr 26, 2021 12:09 PM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
Marino
Sep 12, 2015 11:10 AM
morg65
Escort MK 5 / MK 6
Sep 11, 2015 01:55 PM
markk
Sep 9, 2015 08:11 AM
