cosworth managment?
Old Jul 15, 2011 | 01:41 PM
crighton13's Avatar
crighton13
Default cosworth managment?
hey folks in the middle of done and cvh running cosworth managment but it has a full cosworth inlet manafold. anyway got it in the car got it running but its like a bag of sh*te engine sounds smooth but its popping and banging as soon as you try to rev it. its running dark green injectors on p8 ecu with pectal boards. one idle if you pull out the first ignition lead it doesnt change anything? i think it is because of the cam sensor but not sure any thoughts are very helpfull.
cheers alan
Old Jul 15, 2011 | 03:13 PM
oldford's Avatar
oldford
If the cam sensor has a problem then the car would stall or even not start at all.
Does the engine react to pulling the plug on another cylinder? If yes, then the problem is with the first cylinder. No fuel or no spark.
If you connect a test spark plug to the lead, do you have spark?
Is the 12 volt feed present on the injector for this cylinder?
How much resistance (ohm) do your injectors have?
Old Jul 15, 2011 | 04:51 PM
crighton13's Avatar
crighton13
i can start the can when the cam sensor is unpluged and it runs the same the engine does react on other cylinders yea but first scylinder is getting a spark and good compression im not to sure on how to check the ohm on the injector side of things ??:S lol thanks
Old Jul 15, 2011 | 05:52 PM
oldford's Avatar
oldford
A Cosworth management system usually has it "cam" sensor inside the distributor.
Are you sure you are referring to the correct "cam" sensor?, because without a signal telling what cylinder 1 is, the engine will not start.
Use an ohm meter (Digital Volt Meter) to measure resistance.
Disconnect connectors and measure between the two pins of the injector.
Or remove the complete fuel rail with injectors, wiring, pressure regulator and fuel lines.
Then have somebody start the engine and observe spray pattern on all injectors.
All 4 injectors spray fuel? Roughly the same amount?
If you remove the spark plug from the first cylinder: is it soaking wet or bone dry?
Is the chip in the P8 mapped for your engine?
Old Jul 16, 2011 | 03:41 AM
crighton13's Avatar
crighton13
Well it has been built to take the sensor out dizzy and on cam pully mate ill do all the tests on sunday cheers mate
Old Jul 16, 2011 | 03:52 AM
Gadget's Avatar
Gadget
Spanner monkey
what sensor are you using for the cam sensor? if it's an eec 4 sensor you'll need to swap the two wires around. and what crank sensor are you using?
Old Jul 16, 2011 | 04:35 AM
axelriet's Avatar
axelriet
The ECU does not really need the cam sensor. It's only used for sequential injection, which requires 720 deg sync. In 360 deg sync (without cam sensor signal) the ECU injects half the fuel at every revs and the engine runs reasonably fine!
That said I'd check the crank sensor: make sure the gap is within specs. This is the one sensor you really can't do without and the ECU can easily lose sync if the gap between the sensor and the trigger is too wide, which causes bangs, pops and all kinds of nasty stuff.
Old Jul 16, 2011 | 02:50 PM
crighton13's Avatar
crighton13
ok cheers folks but im not to sure on what cam or crank sensor im running sadly as i bought it built this is why i prefer to build them myself lol
JK12
33
Apr 26, 2021 12:09 PM
Nov 3, 2015 04:08 PM
tonicosworth
Ford Escort RS Cosworth
Oct 31, 2015 08:40 AM
Ade
Alloy wheels and ICE for sale
Sep 7, 2015 05:06 PM
