starting problem
Old Jul 10, 2011 | 09:30 PM
steve_o's Avatar
steve_o
Default starting problem
hi guys, just finished putting the engine back in my s2 today after rebuilding it, however it wont fire up, i have spark and fuel is getting up wen first cranked, it will fire up, run for about 2 seconds then cut out straight away, i can here the fuel pump run wen i turn the ignition on, and it tries to start wen i turn the key, but just wont fire, like its losing the fuel supply, i have checked the pump relay and its a little black inside so hoping its just that but need to be sure, any help wud be appreciated. cheers.
Old Jul 10, 2011 | 10:00 PM
jasper jones's Avatar
jasper jones
First thing i would try, would be to put a test light or multimeter on the fuel pump wires,to see if the power is lost going to the pump;if it is could be the relay,or the signal to the relay
Old Jul 10, 2011 | 10:10 PM
steve_o's Avatar
steve_o
cheers mate i'll give that a go, frustrating, the car hasnt ran in two years, first time i try to start and it doesnt wanna go, i did notice tho that on the odd occasion wen i turn the ignition on i dont here the fuel pump prime, which leads me to think it could be relay but i'll give it a go with the test light, cheers.
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
muffster
13
Sep 3, 2015 09:40 PM
nick8saff
Aug 16, 2015 05:35 PM
Sjieter
Aug 5, 2015 09:47 PM
