Ford Escort MK1 Track Day Car / Engine Conversion
Hi,
I am in the process of building a MK1 Escort for track day use, the restoration and uprating the chassis and body are well under way but the running gear is where I need assistance.
I need lots of help on what engine conversion route to follow !!
To ensure the car is competitive I am thinking of 250bhp + with plenty of torque, I have seen several 2.0 vauxhall conversions etc but more recently an S2000 one ?
I am in need of advice on engines / gearboxes / prop / axle / performance etc etc etc
If anyone can offer guidance, pro's & con's, do & dont's etc etc on the conversion I will be more than grateful.
Thanks,
Stuart.
Thanks,
Stuart.
don't know if its of any help but im lining up an SR20DET engine from a nissan 200sx for my mk2 escort, 250bhp as standard with 7psi of boost, 14psi is the most that turbo will take but wind it up to 10-12psi and you'll be at 270ish with standard internals, gearbox, injectors etc etc. as for axle i'll be hunting down an atlas axle and all the goodies needed to strengthen the rear end. and a complete 200sx can be had for Ł1500, nice. hope that helps a bit,
Harry Hockley have built an s2000 powered mk2 rally car. Swing them an email
http://www.hh-ms.com/contactus.htm
pinto, good power per Ł
n/a cossy, nice in a mk1, 200-250 bhp,good on track.
zetec,good value and go well.got a nice one of them for sale.
turbo yb,allways good
whatever you fancy.
whatever you fancy.
We had 260BHP from an Atmo Cossie lump, it was in a FWD mk6 Escort, everything had to have locking wire around it because it all vibrated loose, christ it didn't half go though!
iv been told off this have you any pictures off your car
Hi,
Was trying to avoid turbo power - I believe in n/a power for long term purposes !
My thoughts are that a pinto won't be fast enough and the XE needs a lot of money throwing at it for good power ?
The S2000 lump is 235bhp standard and very reliable, a set of throttle bodies can improve further and / or modify the vtec to come in at 5000rpm
Am I correct in my thoughts ?
only of it how it looked before it was taken off the road, its running a hot xflow now as i havent gathered the bits for the nissan conversion yet, but it ticks all the right boxes, cheap, reliable, powerful and driveable, nice.
matman
Sep 9, 2015 05:45 PM
track.focus'd
Aug 12, 2015 05:53 PM
Versus_Creations
24
Aug 5, 2015 09:32 PM
