brembos what they worth
hi ive got these brembos for sale but not sure what there worth they were bought and fitted to an audi tt which i sold there was a receipt for £2700 to supply and fit .i took them off because 1 of the pistons was sticking and wore the pads down and as i had a standard set in the shed i changed them back .they come with new rubber seals they are 4 pots and are very light so guessing there aluminum the disks are great condition and are the 2 part ones i was going to keep them for an escort cosworth project but have changed to a 3door so will not get used as i prefer the standard wheel the disk are 326 mm diameter and 26 mm thick and are tarox the calipers are 220mm long and 140 mm wide the calipers are in reasonable condition the faces (seen throught the wheel are great )some paint is comming off were the pipes connect comes with braided lines and brackets to fit you might be able to alter i havent tried
