code P1383, ST170
following on from my previous post "Rough running when hot" , i had the car on a mates scanner and it cam up with the code :
P1383 Variable CAM Timing Over Retarded (bank 1)
Any one have any idea what this is all about ?
i am at my wits end with this , if i cant find a cure i might just end up Breaking the car for parts ..
Any Help would be appreciated...
Pull out the airbox (it pulls upwards, might be stiff though), then underneath on the side of the inlet manifold is a plastic lever with a cable attached to it. Make sure it is still connected and it pulls round 90 degrees when you start the engine.
That fault is normally thrown up when you change the cam belt inccorectly without loosening off the cam pullies, when was the cam belt last done. Could also be the sensor playing up obviously, the sensor is under the plug cover on the left hand side of the cam cover near the inlet pully
any other ideas ? thanks
Is there any way to tell for certain that this is the case ?
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
