narrow band lambda which wire is which ?
Old Feb 10, 2005 | 03:46 PM
CraigN's Avatar
CraigN
Default narrow band lambda which wire is which ?
i have a 4 wire narrow band lambda sensor.
it has
1 grey wire
1 black wire
2 white wires
anyone know what wire is waht ?
im pretty sure the white are for the heater
but are both positive negative or. ????
Old Feb 10, 2005 | 04:24 PM
pee vee's Avatar
pee vee
white ones are the heater wires mate. yep.
If its a Ford Lambda probe, then the grey wire is the Sender wire
(the one for the guage you are hooking up i guess?)
BUT on after market sensors, sometimes the black wire is the
sender wire.. the instructions usually say on the aftermarket ones,
as they are universal..
Old Feb 10, 2005 | 05:28 PM
richm's Avatar
richm
whites are definitely the heater
Bosch sensors (and Ford zetec sensors that I have seen for that matter) are positive signal on the black, and grey is ground side of signal.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Cosnada
Jan 7, 2016 05:30 PM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
Si B
Sep 12, 2015 06:49 AM
