whistling/Whirling Noise from turbo!!!
Old Jun 11, 2011 | 09:14 AM
cosworth_cab's Avatar
cosworth_cab
Never over till its over
Default whistling/Whirling Noise from turbo!!!
Recently brought a Replacement Turbo (2nd hand) fitted it all back up, Took car for a little blip up road,not nothing mad, and as soon as it comes on boost its making a loud whistling/whirling noise!!! Never made this noise before... Any ideas...
thanks
Old Jun 11, 2011 | 09:32 AM
RichieST's Avatar
RichieST
Turbo is either fucked or you've got a boost leak somewhere?
Old Jun 11, 2011 | 09:34 AM
cosworth_cab
Ment too have come off a car with no problems.. Checked pipes, they all seem ok...
Old Jun 11, 2011 | 09:35 AM
milesy23rst's Avatar
milesy23rst
PUG 306 GTI-6
Errr the 2nd hand turbo you bought is on its way out m8 thats a sure sign
Old Jun 11, 2011 | 09:37 AM
ST Turbo's Avatar
ST Turbo
I had a similiar problem, the oil feed was blocked inside the turbo, which caused the bearings to colloapse, and so one of the fins got distorted on the houseing.. I sugguest you take the oil drain off the turbo and see if your getting oil run through it!
Old Jun 11, 2011 | 09:41 AM
cosworth_cab
Def getting oil threw the Turbo, one of the 1st things i checked... I brought the turbo from Jano, his assured me it was fine..
Old Jun 11, 2011 | 09:43 AM
luke19790_3's Avatar
luke19790_3
don't use the car with that turbo again. sounds like the bearings
Old Jun 11, 2011 | 09:44 AM
RichieST's Avatar
RichieST
Just don't forget it could be a genuine mistake, give Jano a chance to sort things for you. Could even have been dropped by the courier which could easily knacker it.
Old Jun 11, 2011 | 09:48 AM
cosworth_cab
Yea Jano is sound, More than helpful.. I went and picked turbo up from him, prob something stupid ive not put on right..
Old Jun 11, 2011 | 10:10 AM
cosworth_cab
Going Janos Now, his gonna have a look... Helpful geeza
Old Jun 11, 2011 | 10:38 AM
Versus_Creations's Avatar
Versus_Creations
Ask me a question!
Strange? That was a really good turbo that came from Turbo Technics.
Not the end of the world, what ever it is we can fix it.
Ill see you soon.
Old Jun 11, 2011 | 02:04 PM
cosworth_cab
TOP TOP MAN.... Brought my car too Oddkidd Creations, thing was running like a dog.. It Come out driving like a new motor and didn't cost an arm and a leg, got advised too go here bye few mates, and definately shall be back..
Thanks for Everything Mate..
see ya soon
Old Jun 11, 2011 | 02:47 PM
Ben26's Avatar
Ben26
cheap bastard lol
Old Jun 11, 2011 | 03:05 PM
RichieST's Avatar
RichieST
Glad it's sorted what was up with it?
Old Jun 11, 2011 | 03:54 PM
cosworth_cab
Lol, what was right with it is more the question, Co Levels were @ 0.2, shud have been 3.0 or there abouts.. Adjusted my idle, the actuator was upside down lol, i hadn't known what had been done 2 car previously, but it had a intenal bleed valve while hooked up too the amal valve, it had diff size pips connected together..totally wrong, but he spent the time too correct it all, now sits at a bar of boost and it is drives spot on... And when he said the price i thought he was joking, cheapppppppp...
Old Jun 11, 2011 | 04:08 PM
phil_focus's Avatar
phil_focus
so nothing wrong with the turbo then lol, glad its all sorted though. just goes to show things may not always be hunki dori under the bonnet so worth checking it all first 8)
Old Jun 11, 2011 | 04:18 PM
cosworth_cab
Yea Turbo was sound mate, (Think it was more me being paranoid) but having said that, the plenum pipe too intercooler was sitting pissed, so sorted that..I drove over 2 janos with out getting it on boost, just 2 b on safe side. But definately true what you say, things look ok,but arent, unless you know what is what.Def worth the trip.. Glad its sorted...
Old Jun 11, 2011 | 08:36 PM
Versus_Creations
Ask me a question!
No problem, glad its sorted for you.
Where do you start lol. Loads was wrong tbh. Im surprised it even made it to me.
The main things was the lack of fuel 0.15%
Ignition timing over 19degree
No bleed off the idle screw
Throttle set to half throttle at idle
Throttle stop wound out so far the butterfly was open way too much
Fuel pump wiring a little suspect
Bleed valve and amal valve piped together with the smallest i.d pipe making it overboost
Then the normal stuff that needs tweaking and adjusting.
Pretty much the same as the other 2 MFi cars setup today had the same common faults.
Old Jun 12, 2011 | 10:24 AM
rickbartlett's Avatar
rickbartlett
G911 TTA
glad its sorted, wish u werent so far away,heard nothing but good things about OKC ,
Old Jun 13, 2011 | 07:24 PM
cosworth_cab
Worth the Journey mate
JK12
33
Apr 26, 2021 12:09 PM
Matt Baxter
Sep 16, 2015 08:30 PM
kevin36
Sep 2, 2015 06:24 PM
Michael Wisbey
Aug 14, 2015 11:57 PM
Churtz
15
Aug 13, 2015 06:40 PM
