is it posible to run two seperate intercoolers
Old May 26, 2011 | 10:37 AM
djvu's Avatar
djvu
Default is it posible to run two seperate intercoolers
Got a front mounted pace on the car and a rover coupe in my hand can the two be conected up
Old May 26, 2011 | 10:52 AM
Chip's Avatar
Chip
*** Sierra RS Custard ***
Absolutely yes they can, but bear in mind that in doing so you are going to be passing already cooled air from the first into the second, so the second will be less efficient as a result, and yet will still be a hinderance to flow.
Ie it will function like a very long intercooler would in the first place, and there are reasons intercoolers tend not to be wider than about 2 foot generally.
Old May 26, 2011 | 11:34 AM
phil_rs's Avatar
phil_rs
yam yammer
I would personally just buy a good second hand GRS or Radtec one. Then again the Airtec ones are fantastic for the money and come with a superb kit
http://www.autospecialists.co.uk/Pro...oduct-663.html
Old May 26, 2011 | 12:14 PM
ajamesc's Avatar
ajamesc
cossie fan (unluckerly)
renault 21 turbos have 2 small intercoolers
Old May 26, 2011 | 12:17 PM
Joshy's Avatar
Joshy
Dreamer
i would imagin that the pace cooler is more than up to the task unless your a really high spec and are getting high intake charge temp's.
no need for another cooler if the current one is working fine.
but yes its possible.
Old May 26, 2011 | 12:36 PM
axelriet's Avatar
axelriet
Not sure if it would make sense plumbing-wise, but you could run the two IC's in parallel with 'Y' ducts instead of one after the other. This should reduce the pressure drop.
Old May 26, 2011 | 12:37 PM
Chip's Avatar
Chip
Yes that is one way to do it and will mean that both still have a chance to be efficient as both will see hot air.
The downside is the way that the y pipes will hinder flow of course.
Old May 26, 2011 | 12:41 PM
Phil2002's Avatar
Phil2002
will also so increase lag. as said above if your worried about high intake temps fit an intercooler spray kit or water injection.
Phil
Old May 26, 2011 | 12:54 PM
axelriet's Avatar
axelriet
This should be less than running two ICs serially: parallel will likely increase flow. The only real question is if it's doable with reasonable plumbing, i.e. not needing to go round the engine bay twice or something.
Old May 26, 2011 | 01:04 PM
zippyobrien's Avatar
zippyobrien
I've seen a chargecooler feeding an intercooler. Due to space (or lack of it)
Old May 26, 2011 | 01:37 PM
Chip's Avatar
Chip
Agreed, but then it would be as the air is only going through one cooler not both, so that means you get some hinderence to flow with the extra pipework, but unlike the hinderance to flow of a serial setup it doesnt result in the air being cooled twice.
It depends really if the problem he has with 1 intercooler is wether it doesnt flow enough or doesnt cool enough as to which method of adding a second would be better.
But personally I would just fuck them both off and get one decent one instead!
Old May 26, 2011 | 01:47 PM
mobb-black's Avatar
mobb-black
TT's use a twin setup
Old May 26, 2011 | 03:43 PM
muz's Avatar
muz
Wye Valley Hardcore
A lot of new cars use twin intercoolers merely because of space constraints. My Abarth 500 has twin coolers.
Old May 26, 2011 | 04:02 PM
homer j's Avatar
homer j
also i'd have thought if you plumb them in one after the other it'd be much like using a twin pass cooler rather than two seperate ones?
Old May 26, 2011 | 04:15 PM
djvu's Avatar
djvu
Cheers chaps, my spec is mfi 203bhp with pace intercooler see thread a few down from this for full soec, someone did mention about the pace not really up to the job and my temps will be high, how can i measure them , this intercooler will cost me nothing so its just a fettle n see
Old May 26, 2011 | 04:33 PM
djvu's Avatar
djvu
Where does the standard intercooler fit? This one looks almost kike it so imagine the standard rs plummed into pace...... Botchit scrper nothing to loose
Old May 26, 2011 | 05:47 PM
Oranoco's Avatar
Oranoco
Do you mean PACE front mount or the PACE double capacity as the 2 are very very different. I'm running 25psi through my PACE front mount with 260bhp and am not at the units limits yet. The double capacity PACE unit struggles with anything much over 12-14psi
Old May 27, 2011 | 09:14 AM
homer j's Avatar
homer j
as above mate, if it's just the doulbe capacity one then i'd say get it changed or try and fit this other one in the system with it. can't hurt to try new stuff on a budget.
JK12
33
Apr 26, 2021 12:09 PM
155lee
Oct 27, 2015 04:55 AM
simonmcf
Sep 22, 2015 08:40 AM
tib2220
Sep 14, 2015 12:33 PM
Eigdoog
Sep 13, 2015 05:46 AM
