St220 / st200
Old May 25, 2011 | 11:25 PM
Colin Brooker's Avatar
Colin Brooker
Default St220 / st200
Is the Mondeo ST220 engine a replacement for the ST200 or are there other parts that will need changing, like the Controller, sensors any information gratefully received.
Old May 26, 2011 | 02:42 AM
monkeyra's Avatar
monkeyra
The ST220 is a 3.0 (Duratec 30) whilst the ST200 is a 2.5 (Duratec 25). Essentially the same, but larger. What are you trying to do?
Old May 26, 2011 | 08:52 AM
Colin Brooker
My ST200 Has big ends gone, so I am thinking about fitting an ST220 which apparently has some refinements to the sump that help protect the possibility of oil starvation and less likely to big end trouble.
Plus, I am more likely to find a good 220 engine than a 200 that may be on it's way out.
Old May 26, 2011 | 09:04 AM
monkeyra's Avatar
monkeyra
Are you planning on swapping the entire engine over then, or interchanging parts between the two engines?
The "3.0 Swap" is rather well documented on contour.org, well worth a look on there
Old May 26, 2011 | 09:34 AM
Colin Brooker
Cheers, I am trying but having trouble with setting up a login, may have to wait until I get home
Old May 26, 2011 | 09:36 AM
Colin Brooker
sorry, I am planning on using the whole engine, but a bit concerned about the engine management.
malkiemac3579
Jul 14, 2017 12:10 PM
Si B
Sep 12, 2015 06:49 AM
blakey100
Aug 4, 2015 08:17 PM
ster
Feb 5, 2006 06:30 PM
Daveyraveygravy
Sep 7, 2004 08:53 AM
